Sponsored by:
Sponsored by:
Shaker 500 audio noise
Old 07-29-2009, 05:54 AM
  #41
wilkinda
2010 Section Moderator
wilkinda's Avatar
Originally Posted by robinsonda1
Good, I like that system and the web site wasn't really clear about that.
I just looked at my Window Sticker and it states Shaker 500 and Electronics package (Nav).
The system is awesome by the way. Trying not to crash and play at the same time
wilkinda is offline
Old 07-29-2009, 09:10 AM
  #42
8178A
8178A's Avatar
All the shaker 500s and 1000s have this noise including my 07 and 09.
8178A is offline
Old 07-29-2009, 10:20 AM
  #43
Adam
Adam's Avatar
I have a feeling this is a different problem otherwise why would it have been fixed so quickly with the new model '10s?
Your noise is exactly what we have described above? You can hear AM/FM leaking through on other inputs? You can VERY clearly hear the noise when sitting upright in the drivers seat? The noise volume doesn't change when you raise the radio volume?
Adam is offline
Old 07-29-2009, 12:03 PM
  #44
richmod
richmod's Avatar
Is this issue exclusive to '10s?
richmod is offline
Old 07-29-2009, 04:19 PM
  #45
8178A
8178A's Avatar
I’m talking about what the OP said, “low volume continuous static like noise that comes from the system”. Noticeable with the volume off or when there is no sound being played or broadcasted. My 07 and 09 has the problem as well as other Mustangs I checked at the dealer.
8178A is offline
Old 09-12-2009, 01:11 PM
  #46
Napoleon85
Napoleon85's Avatar
Tagging this for follow up once I get my stang. Any updates?
Napoleon85 is offline
Old 09-12-2009, 01:26 PM
  #47
Adam
Adam's Avatar
The headunit issue has been fixed in the Job2 and later 2010 Mustangs.
Adam is offline
Old 09-12-2009, 07:07 PM
  #48
Napoleon85
Napoleon85's Avatar
Is there a way to verify whether you have the Job 2? I only saw a way to (perhaps) verify that you had a Job 1? Did anyone with a Job 2 run that process and verify that the code is different?
Old 09-13-2009, 11:58 AM
  #49
FordEngineer
FordEngineer's Avatar
If you can check out the window sticker (stock vehicle) or 'print' your window sticker (ordered vehicle), it should be on that.
FordEngineer is offline
Old 09-14-2009, 03:51 PM
  #50
Napoleon85
Napoleon85's Avatar
http://services.forddirect.fordvehic...BP8CH1A5144937
This is the one I'm looking at.
Quick Reply: Shaker 500 audio noise
