Sponsored by:
Sponsored by:
additional things for long tubes install?
Old 07-22-2009, 01:27 PM
jlugo_70
jlugo_70's Avatar
Default additional things for long tubes install?
is there anything else i should get before i install my long tubes? like gaskets or something like that? im getting new motor mounts and the sensor extensions aswell.
jlugo_70 is offline
Old 07-22-2009, 01:28 PM
SirKnightTG
SirKnightTG's Avatar
If your headers did not come with gaskets you need them. Otherwise you'll have a HUGE exhaust leak.
SirKnightTG is offline
Old 07-22-2009, 01:54 PM
jlugo_70
jlugo_70's Avatar
i bought them thru another forums member. so i will need them?
jlugo_70 is offline
Old 07-22-2009, 03:12 PM
rshamekh
rshamekh's Avatar
Yes, you will need new gaskets.
You will also need new bolts. I went with the stage 8 locking bolts.
rshamekh is offline
Old 07-22-2009, 03:34 PM
zkiller
zkiller's Avatar
No you dont. Just re-use the metal OEM gaskets because the aftermarket gaskets suck.
I used my OEM gaskets they worked great no leaks and easy to put in place on the headers.
zkiller is offline
Old 07-22-2009, 04:05 PM
Rubrignitz
Rubrignitz's Avatar
Agreed. They reused my stock metal gaskets and I'm still leak-free (the headers at least! ) two years later. The rest of my exhaust is another matter...small holes keep forming (hot spots???) in my h-pipe..
I also used stage 8 locking bolts.
Rubrignitz is offline
Old 07-22-2009, 04:35 PM
bigray327
bigray327's Avatar
Gloves and Prozac.
bigray327 is offline
Old 07-22-2009, 10:55 PM
jlugo_70
jlugo_70's Avatar
well the jba headers i bought from the member came with bolts. so it is recommended to buy new stock gaskets?
jlugo_70 is offline
Old 07-23-2009, 02:17 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
yup just reuse the stock ones!
no need just reuse the stock ones you have now...I would recommend the stg 8 locking bolts if those are not the ones that came with your jba's.....do it once and get it right the first time
mygt500 is offline
Old 07-23-2009, 07:28 AM
Srt2Stang725
Srt2Stang725's Avatar
Originally Posted by bigray327
Gloves and Prozac.
lololol +1000000
Srt2Stang725 is offline
Quick Reply: additional things for long tubes install?
