Sponsored by:
Sponsored by:
TSB 08-2-10 question
Old 10-13-2011, 11:58 AM
  #21
FordService
Official Ford Rep
FordService's Avatar
Originally Posted by jonesaw
I have an 06 Saleen (manual) and I experience a metalic sounding rattle at startup. To me it sounds like it is coming from the front of the trans or back side of the engine.
Hi jonesaw,
I reached out on your post on a different forum, but please PM me your VIN (on either forum) so I can review your situation. Talk to you soon.
~Natasha
FordService is offline
Old 10-13-2011, 12:08 PM
  #22
White05GT
White05GT's Avatar
TSB's are usually free only when done under the warranty period, after that they usually charge you. Really depends on your dealer also.
White05GT is offline
Old 10-31-2011, 07:24 PM
  #23
jonesaw
jonesaw's Avatar
Default SOLVED THE RATTLE
It was the exhaust mounts for the H pipe.
I ordered a new seperator plate and replaced it myself. I thought for sure that was the problem. There was even a shinny spot on the old plate right where the new plate had the cut out. But sure enough, I hear it as soon as I start it up. In fact it got worse, which made it easy to identify as the H-pipe exhaust hangers. I initially suspected the hangers and got under the car and hit them with a dead blow hammer but never heard anything. I guess since I had H pipe out to swap the plates I must have move it just enough to make it worse. After still hearing the noise after installing the new plate, I hit them again and it was clear that they were making all the noise. Even thought the exhaust hangers were perfectly centered inside the rubber isolators, the metal c-clamp would vibrate against the cross member at certain frequencies.
Removed the hangers and problem solved.
jonesaw is offline
Old 10-31-2011, 07:25 PM
  #24
jonesaw
jonesaw's Avatar
Default Problem solved - Exhaust hangers!
It was the exhaust mounts for the H pipe, making all the noise at cold startups.
jonesaw is offline
Old 10-31-2011, 11:22 PM
  #25
White05GT
White05GT's Avatar
Glad you fixed it!
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: TSB 08-2-10 question
