Sponsored by:
Sponsored by:
15 x 10 Welds
Old 09-27-2009, 07:14 PM
Whiteflash454
Whiteflash454's Avatar
Default 15 x 10 Welds
I got a friend with 15 x 10 Weld Draglites 5 x 4.75 with a BS of 3.5 will these fit my rear?
Thanks KC
Whiteflash454 is offline
Old 09-27-2009, 07:17 PM
Miracle
Miracle's Avatar
Yes, but you will need to either remove your rear sway bar, and cut it's bracket off the axle tubes, or get BMR's relocation bracket.
Miracle is offline
Old 09-27-2009, 07:23 PM
Whiteflash454
im thinkin the relocation brackets are easier..lol
Old 09-27-2009, 07:24 PM
Miracle
Miracle's Avatar
True... just make sure the backspace on the wheels is about a 7.5 inch BS on the rears, and you should be fine.
Miracle is offline
Old 09-27-2009, 07:26 PM
Tylus
Tylus's Avatar
I thought we couldn't run 16" or smaller because of the brake rotor/calipers?
Tylus is offline
Old 09-27-2009, 07:28 PM
Miracle
Miracle's Avatar
Common misconception. As long as you get the backspacing correct, and possibly run spacers, you shouldn't have an issue... see this 24 page thread on nothing but 15" wheels.
http://s197forum.com/forum/showthread.php?t=13158
Miracle is offline
Old 09-27-2009, 07:45 PM
Whiteflash454
MIRACLE
I just said that the BS is 3.5 , and u said as long as I get the Relocation brackets ill be fine..?
Old 09-27-2009, 07:49 PM
Miracle
Miracle's Avatar
MIRACLE
That's for the front wheels... you need to find out the backspace on the rears... and since they are 10" wide, the BS needs to be about 7.5 inches on the rears.
Miracle is offline
Old 09-27-2009, 07:57 PM
Whiteflash454
ohhh ok cause i asked bout my rears i guess u didnt see that...all good
So if I get 15 x 5's for the FRONT the backspacing is still 3.5 right? and i will need a spacer as shown?
Old 09-27-2009, 08:41 PM
8178A
8178A's Avatar
When you have the tires mounted on them make sure they know what they are doing. Those are great light weight wheels but then can be bent so easily you will not believe it. Love the look of 15s on the Mustang. When you see them you know the owner is after real performance not bling!
8178A is offline
Quick Reply: 15 x 10 Welds
