Crap.. Need help with Intake Part #
Hey guys,
While transferring my CAI back to stock to take it to the Stealership so they could fix my airbag issue, I pulled too hard on this little plastic piece "reducer" that goes into a vacuum tube and busted it in half. The piece in question can be found here:
http://www.steeda.com/directions/555...ttube-s197.pdf
It's in picture #1. It's a little piece that goes into the small hose on the side of the inlet elbow on one end, and connects to a quick disconnect L-shape thing on the other. I'm trying to figure out what it is, and where I can get another, or atleast a part # for it! I taped it back up and got a P0113 code, so I know it's not working right. I have to go on a trip tomorrow afternoon, so need to get this replaced asap! Any ideas?
If you had any *********, you wouldn't have bothered removing the CAI and this wouldn't have happened. Especially since it was for the air bags.
Have you contacted Steeda?
I suppose having an airbag deploying properly saving my life in a past wreck makes me biased on this matter, so my bad if that makes me have no *********.
Yes, I've tried contacting them. They are closed.
I agree with that, but my Dealer is very picky about tunes and mods, so I do my best to give him no reason to gripe about it. That being said, this doesn't help me solve my problem. I've been looking through all sorts of websites, and can't find anything about it. Any ideas?
As far as the part, it's hard to tell without one removed from the tube if it's something you might be able to find at a well-stocked plumbing supply house or not. Almost looks like a simple reducer. If you're throwing a code, it seems it would be related to air in-leakage and maybe some RTV as a quick-fix until you get a suitable replacement may work. Just a guess.
I just looked at this article:
http://www.americanmuscle.com/cl-rac...t-install.html
The rubber tube that branches off from the left of the new air elbow looks like it works just fine. Anyone know if that is just rubber hosing or what? I can prolly pick that up at any auto parts store.
