v6 "fog lights"
v6 "fog lights"
does anyone know the size dimensions of the v6 "fog lights?" they are the lights with the pony package that are in the grille. i was thinking about putting them in the lower grille just not sure if they would fit and i don't know of anyone with them to check. and if they do fit, would they require a different harness than the gt fogs or can they use the same harness
'removed and remounted'.
The OEM supplied GT to PP pigtail adapter would be needed.
The harness has GT fog connectors but the PP has these short
wire extender/plug changing pigtails.
Its not hard to do im just not familiar with the V6. I installed a GT/CS front bumper in my 07gt and installed the PP fogs in the lower bumper. They are 3.5inchs Think I used a 3 5/8 hole saw for install just for clearance on the sides. The lights are round but the backing is not fully round.
And like my man said above you just need the GT foglight pigtail. Plug N Play if i remember correctly.
Good Luck
Good Luck
Diode Dynamics
28
05-26-2022 12:02 PM
