Sponsored by:
Sponsored by:
got the shock and springs
Old 10-26-2009, 07:27 PM
deekum1627
deekum1627's Avatar
Default got the shock and springs
tring to install this weekend but looks like rain so well see. so i have the koni STR.T and ebich pro springs, now im goin to get eibach swaybars i think. so what else suspend wise should be changed im thinking a panhar bar. now i dont race its just a street car for me but i do wnat to improve it. thanks for the help
deekum1627 is offline
Old 10-27-2009, 01:26 AM
White05GT
White05GT's Avatar
Might want to put in the upgraded strut bearings if you have the front end noise that is covered in the TSB.
White05GT is offline
Old 10-27-2009, 11:08 AM
deekum1627
deekum1627's Avatar
what is that about i dont have a noise but more info would be great
Old 10-27-2009, 11:19 AM
Doogie65
Doogie65's Avatar
Hopefully the weather will cooperate as I am sure these parts will really change the handling of your car!
Doogie65 is offline
Old 10-27-2009, 11:20 AM
08SilverStang
08SilverStang's Avatar
If you don't have a noise then I would not mess with those bearings.
Since you have the pro-kit, I would probably get an adjustable pan-hard bar to get ther rearend centered up nicely. I have the Sportline Springs and I got the BMR adjustable pan-hard bar, and I have been happy with it.
Sounds like you have a good set-up with your suspension
08SilverStang is offline
Old 10-27-2009, 11:38 AM
deekum1627
deekum1627's Avatar
thanks ill start looking for and adj panhard bar
Old 10-27-2009, 11:47 AM
deekum1627
deekum1627's Avatar
http://www.ninosport.com/BMR-Panhard...6-p/phr006.htm or this one
http://www.cheperformance.com/CartGenie/prod-160.htm
Old 10-27-2009, 11:51 AM
StickShifty
StickShifty's Avatar
dont get the Steeda Adj Pan bar, its very hard to adjust when in place. The BMR unit has the adjustments right out in the open for you. And the springs and shocks install is easy. Just takes some time and patience, it will pay off in the end!!
StickShifty is offline
Old 10-27-2009, 12:33 PM
gman73
gman73's Avatar
I would replace the strut bearings. Right after I installed my shocks and struts, the car began to make a clunking popping noise when going over bumps. The OEM strut bearings are often one time use.
gman73 is offline
Old 10-27-2009, 08:36 PM
deekum1627
deekum1627's Avatar
what are the strut bearings where can i get them? so im better off getting the bmr panhard over the che
Quick Reply: got the shock and springs
