Sponsored by:
Sponsored by:
Second USB port for Sync
Old 11-17-2009, 08:54 AM
zago
zago's Avatar
Thumbs up Second USB port for Sync
Just took posesssion of my 2010 V6 convertible with Sync.
Great technology, pretty much got it figured out and working real well.
Decided that instead of keeping my iPod in the car, I would copy playlists to a usb drive and not have to worry about it getting stolen or bumped around.
Came across a thread on an F150 board which states that the Sync module, under the dash has a second USB port that you can install a dedicated USB drive into instead of the one in the armrest storage.
http://www.fordf150.net/articles/idx...t-to-SYNC.html
Anyone know where the Sync module, or second USB port is on the Mustang ?
Thanks
zago is offline
Old 11-17-2009, 09:54 AM
Adam
Adam's Avatar
Very interesting. That's cool. I imagine it would be the same in our cars - but where is that sync module located?
Adam is offline
Old 11-27-2009, 02:56 PM
dspaco
dspaco's Avatar
look behind the glove box
dspaco is offline
Old 11-27-2009, 04:03 PM
FastDEW
FastDEW's Avatar
Will the SYNC unit play only MP3 or will it also play an iTunes download without the iPod?
FastDEW is offline
Old 11-27-2009, 05:14 PM
douglasland
douglasland's Avatar
It should play iTunes files provided you got them after Apple went 100% DRM free. If you aren't sure look at the extension. Original protected iTunes files end in m4p. DRM free iTunes music should end in m4a.
douglasland is offline
Old 12-04-2009, 12:09 PM
FordEngineer
FordEngineer's Avatar
The second USB port on the module has a micro-USB connector on it (like the kind that attach to cell phones or digital cameras). Most cables that have the micro-USB on one end have a USB-A/Male connection on the other. You might need to do some digging to find an appropriate cable for what you want to do.
Also, the Micro-USB ports on the module are designed to work with special wiring harness connectors molded to the micro-USB end of the SYNC USB harness. Make sure your Micro-USB cable doesn't have too big of a molded plug to it, or else it's not going to fit in the recess where the Micro-USB port is.
FordEngineer is offline
Old 12-04-2009, 12:33 PM
motorman524
MF Informant
motorman524's Avatar
Anyone know where it would be on my 08 Focus?
motorman524 is offline
Old 12-04-2009, 12:46 PM
FordEngineer
It's behind your dash finish panel on the passenger's side.
Step 1.) Open glove box.
Step 2.) Completely lower glove box (release so that it drops all the way down)
Step 3.) Position yourself under glove box opening with flashlight.
Step 4.) Look up. Connectors should be on the bottom of the module.
Old 12-04-2009, 12:51 PM
motorman524
MF Informant
Just went and looked, sure enough there it was. Thanks!!
Old 12-04-2009, 01:01 PM
douglasland
On this topic:
Is the Operating System for the NAV on the 10GB Hard disk?
What will work when the 10GB hard disk fails?
Can I backup the 10Gb Hard disk?
Can I upgrade the 10Gb Hard disk?
Quick Reply: Second USB port for Sync
