Anyone else had bad Battery terminal corrosion?
If its bad enough corrosion then it could have traveled down your cable and then the warranty would come into play, I just had to replace my whole positive cable to, my terminal was cables were so messed up that my terminal was smoking...... yeah smoking.. Take some coke or pepsi and pour it on the terminal and let it sit for a little bit, then u can get a wire brush and clean it off. check to see if its heating up after you turn the car on, if it isn't than you just have normal wear and tear. Doubt you will need a visit to the dealer.
mine was so screwed up, it corroded the retaining post as well. when i went to replace everything it broke off about halfway down, then a three hour struggle began trying to cut around the retainer to get the battery out. then two days later after i had to replace the whole battery tray, everything is better than stock! B.S!!
Every year? Maybe do it more frequently. After cleaning, coat the posts and terminals with a protectant, such as petroleum jelly or a protective spray that you can find in an auto parts store.
KingRando
10-02-2015 08:06 AM
logan409
09-26-2015 07:43 PM
