Sponsored by:
Sponsored by:
Anyone else had bad Battery terminal corrosion?
Old 11-19-2009, 03:55 PM
luckydawg003
luckydawg003's Avatar
Default Anyone else had bad Battery terminal corrosion?
My positive battery terminal is all gunked up with corrosion. Has this happened to anyone else's Mustang? How did you clean it, or will the dealer cover it since my car is still under warranty?
luckydawg003 is offline
Old 11-19-2009, 08:04 PM
cobra0478
cobra0478's Avatar
I cleaned my positive terminal on my 07 GT @ once a month,starting when I bought it.
The terminal finaly rotted away from the corusion.
The dealer was glad to replace the harness that included the positive cable,under warranty,as well as the battery that was cracked around the post.
The battery being cracked(probably since the car was new)leaking acid fumes caused the corrosion.
Check with your service dept.
Don
cobra0478 is offline
Old 11-19-2009, 09:02 PM
Mr. Ugly
Mr. Ugly's Avatar
Not mine, but I ran into another Mustang owner a few weeks back who said it happened to his.
Mr. Ugly is offline
Old 11-19-2009, 11:39 PM
Art161
Art161's Avatar
I have not had the problem. I coat the posts and terminals with petroleum jelly. There are also pads available to put around the posts, before the terminals are connected to the posts. For cleaning, baking soda and water mixed to form a paste is good. Work it around with an old toothbrush and then rinse with plain water.
If your battery is cracked, I doubt any of the above will work. They are more to prevent corrosion from the normal outgassing of a battery.
Art161 is offline
Old 11-20-2009, 08:14 AM
Nuke
Nuke's Avatar
Usually, that white crud around the terminal is an indication that the battery case is cracked and is offgasing. The thru-case terminal points are "weak links" in the casing and are prone to this. If this is the stock Motorcrap battery it's probably about time to consider a new battery anyway.
Some have been able to get their dealership to provide a new battery under warranty. IMPO, I wouldn't count on it.
Nuke is offline
Old 11-20-2009, 09:21 AM
kevinmalec
kevinmalec's Avatar
I have been experiencing battery corrosion on my positive cable as well. I clean it with a toothbrush, water/baking soda and put a pad down around the post. It seems to help.
kevinmalec is offline
Old 11-20-2009, 10:18 AM
08SilverStang
08SilverStang's Avatar
Happens to all cars with enough time, especially if you don't use preventatives for this problem. Just use some water and baking soda, or buy battery terminal cleaner. Just make sure you don't let it get too bad before cleaning or there will be more permanent damage to the terminals or clamps.
08SilverStang is offline
Old 11-20-2009, 11:00 AM
157dB
Cut & Paste Expert
157dB's Avatar
Negative on the baking soda.
If just a little bit gets inside a battery
cell and its downhill for that battery.
CDC Battery Cleaner with Acid Indicator
There are products out there to remove the corrosion
and other products to prevent it from coming back as well.
The good stuff is made by CRC and its red in color...
www.crcindustries.com
My positive connection went south bout 6 months old and
I fixed it. 2 years later and no more corrosion.
I touch up the connections with the spray everytime
I am under the hood.
Take that leaky motorcraftola 'sealed' leaker.
The green and red pads help also - unless youi
put the green pad on the positive and the red
pad on the negative.
Attached Thumbnails Anyone else had bad Battery terminal corrosion?-img_4394.jpg   Anyone else had bad Battery terminal corrosion?-crc.jpg   Anyone else had bad Battery terminal corrosion?-crc2.jpg
157dB is offline
Old 11-20-2009, 04:41 PM
D'prived
D'prived's Avatar
No problems with mine so far.
D'prived is offline
Old 11-20-2009, 05:18 PM
luckydawg003
Well I bought some of the Battery terminal cleaner. Guess I will try to clean it tomorrow or I will call my Dealer and ask if they can do it for me. Depends how bad the terminal got eaten. Thanks for the help.
Quick Reply: Anyone else had bad Battery terminal corrosion?
