Correct voltage on KB boost a pump?
Does anyone know the correct voltage i should set my boost a pump at? I have the 40amp kit and i dont believe i saw my tuner set touch my boost a pump voltage. Im making 425rwp on a 3.625 whipple pulley and the voltage is set on 40. Any input would be great. Thanks!
i believe there are two possible settings
for the BAP:
1) Max voltage
2) Some voltage below Max.
if for whatever reason you don't like the idea of
running the BAP at the Max setting, you would
set it at a value that would result in a (chosen)
fuel pump duty cycle (ie. 95%) at your maximum
WOT rpm.
this is a good chance for us all to learn about the
BAP, maybe someone else will weigh in and give
more insight.
for the BAP:
1) Max voltage
WOT rpm.
more insight.
Your question leaves much to be desired in the comprehension dept.
I really doubt your pump is running at 40 volts...
40 amps, maybe, but not 40 volts.
Reread and restate the question again.
Are you setting amps or volts?
And whats a 'tuner set touch'
I would set it with the pressure desired at the widest injector pulse width.
Back to the tuner for more dyno pulls...
Voltage or amperage?
Sorry i meant 40 amps. I just checked and im at 40 amps which is the max, so does that mean im maxing it?
When i said "tuner set touch" it was a mistake and was suppose to be "i dont think the tuner set/touch my boost a pump. Sorry for the confusion.
running it at max will give you 17.2 volts give or take, turning the **** all the way down will give you around 14 volts. just turn it all the way up. on mine i didnt even use the ****,i just spliced the 2 wires together to make it run on max all the time,no chances of anything ever happening to the **** to make it go down.
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
boost, boosta, boostapump, boots, installation, instillation, kb, knob, mustang, pump, setting, test, troubleshooting, voltage, volts
