Sponsored by:
Sponsored by:
Is my Battery a victim of my Shaker 1000?
Old 11-25-2009, 08:43 AM
Nuke
Nuke's Avatar
FYI, if you're checking battery voltage to help determine if you're battery is on the verge of taking a crap (btw, this method is not accurate at all but better than nothing), be aware that there will be a residual charge on the battery from the alternator charging the battery from the last drive. This residual "surface" charge typically "decays" after 12-24 hours and can give false indications that the battery's at-rest voltage is better than what it really is. Just like getting on the scale 1st thing in the morning to check your weight, take a voltage reading after the car has sat overnight and before you start it. I'd raise an eyebrow if it's consistently below 12.6 volts. Also, if you can get someone to crank the engine while you watch the meter, voltage should not dip below 9.6 volts (this is temperature dependent and could go lower the closer you get to 0 deg. F). And like everything else, please be careful when doing ANY work under the hood. Safety first.
However, best bet is to find a place that will do a free load test.
Nuke is offline
Old 11-25-2009, 02:15 PM
S281 E
S281 E's Avatar
Switched mine for a redtop. Hasn't died yet.
S281 E is offline
Old 11-25-2009, 03:57 PM
157dB
Cut & Paste Expert
157dB's Avatar
Originally Posted by Tylus
@ 157db - What fuses?
Read owners manual for the 6 or so shaker fuses for the shaker amps.
157dB is offline
BOB ROME
07-26-2023 01:54 PM
4cylinderplus2
10-09-2020 07:45 PM
logan409
09-26-2015 07:43 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Is my Battery a victim of my Shaker 1000?
