How do you remove the damn Grille?
While I was deployed my Eleanor Grille came in...and I want to install it now.
But how do you get the damn stock grille off? I don't want to damage the grille just in case I'm not a fan of the new look
help please. seems like it would be easy, but in my head...and clumsy hands, I can easily see a bunch of broken plastic tabs
There are some clips that go into the bumper
you pry them up as you slide the grille away from the bumper
there are quite a few and its a pain to do
i did mine when the bumper was removed, very easy and the flex of the bumper makes it easier to get them out
there are clips on the bottom of the grille also i beleive
use a small flat head with a towell over it so not to damage the bumper
Go here: http://iihs.net/fsm/?dir=1
Then dig down to the body section and you'll find the steps for the grill removal. IMO, it STILL will be harder than you'd think.
Glad you are back safe and sound and thanks for your service brother. As for the grill, Im a big fan of the bullitt grill but use these instructions to get your grill off. They are the best instructions and what I used in my old look. Just take your time as some of those tabs are a bitch and a friend around will be more than helpful.
http://www.streetsceneeq.com/instruc.../950-73595.pdf
This is your best bet.
I figured it out by myself when I had to install my HID fogs into my GT. It's a little bit of a PITA but it's not that hard. Just take your time so you don't break anything. Also no need to remove the whole front bumper, although it will make it easier it will take a little longer. People say the front bumper is only 6 bolts which is true, but it still is time consuming.
jwog666
12-27-2021 08:09 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
