Sponsored by:
Sponsored by:
Best $2.27 mod ever.
Old 11-28-2009, 02:47 PM
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
That is as clever as it gets
MELLOWYELLOW06 is offline
Old 11-28-2009, 04:16 PM
Moderator
JimC's Avatar
Originally Posted by Justin05GT
If you loaded the stock tune back on before you went to the dealer you wouldn't have to worry about this correct?
Not necessarily. If they reflash it can change your strategy code just enough that your custom tune won't load back properly.
JimC is offline
Old 11-28-2009, 04:45 PM
Nuke
Nuke's Avatar
Yes you WOULD still have to worry about it. With any tune, the dealer can still reflash the PCM, leaving you screwed when you try to reinstall any of your tunes.
Nuke is offline
Old 11-28-2009, 06:17 PM
loots06
loots06's Avatar
Sweet....
loots06 is offline
loudnlow
loudnlow's Avatar
If this happened how would you be able to get your tunes back on the car properly
loudnlow is offline
Old 11-29-2009, 09:51 AM
Diabolical!
Diabolical!'s Avatar
If I loaded the stock tune before I went to the dealer, I wouldn't make it to the dealer, lol.
Diabolical! is offline
Old 11-29-2009, 09:52 AM
Diabolical!
You would have to have a tuner pull the strategy codes and write new tunes to fit.
Old 11-29-2009, 11:00 AM
Nuke
Nuke's Avatar
The bottom line is, the dealer should not be touching anything on your car, ESPECIALLY THE PCM, without your consent. With nineinchnail's mod, you've added another "administrative barrier" that should help prevent it (although I'm sure some of Ford's techs can't read). At least the dealer can't say "You never told us."
Nuke is offline
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
TimeLord101
10-01-2015 06:40 AM
09-18-2015 06:49 PM
Quick Reply: Best $2.27 mod ever.
