Sponsored by:
Sponsored by:
Pumpkin Jackers Beware
Old 12-07-2009, 06:11 AM
robs
robs's Avatar
Originally Posted by 6-Speed
Did you just bend the cover with the jack or was there more damage to the differential casing?
It don't hurt the casing... just bends the lip of the whimpy aluminum cover... I've got a steel 8.8 cover that I'll replace it with.
robs is offline
Old 12-07-2009, 08:07 AM
Nuke
Nuke's Avatar
Darned Owners Manual! I HATE it when it's right... -jacking... DOHHH!
Nuke is offline
Old 12-07-2009, 10:31 AM
loots06
loots06's Avatar
wow...thats clean..
loots06 is offline
Old 12-07-2009, 10:34 AM
hammeron
hammeron's Avatar
clean machine
hammeron is offline
Old 12-07-2009, 11:03 AM
157dB
Cut & Paste Expert
157dB's Avatar
I knew it would happen sooner or later.
Non Pumpkin Jacker
157dB is offline
Old 12-07-2009, 11:21 AM
Riptide
Riptide's Avatar
This is what happens when you aren't CAREFUL. The only way that cover gets pinched is by putting the saddle under it. The saddle should go slightly behind it and not be touching the edge of the cover.
Riptide is offline
Old 12-07-2009, 11:32 AM
Lv XLR8N
Lv XLR8N's Avatar
i also use a block of wood I kinda fabbed something up so that it supports towards the front of it. kinda looks like a step. I also stay away from the cover dont need to bend it.
Lv XLR8N is offline
Old 12-07-2009, 11:45 AM
Riptide
Riptide's Avatar
I've seen some differential covers that don't have an edge hanging down over the bottom of the diff itself. You don't have to worry about pinching those because it doesn't get in the way.
Riptide is offline
Old 12-07-2009, 11:50 AM
2011Black5.0
2011Black5.0's Avatar
this is exactly what mine looked like when i got it, then i got the LPW cover and didnt have to worry about pumpkin jacking
2011Black5.0 is offline
Old 12-07-2009, 12:29 PM
SirKnightTG
SirKnightTG's Avatar
Giggity!
SirKnightTG is offline
Quick Reply: Pumpkin Jackers Beware
