Sponsored by:
Sponsored by:
Pumpkin Jackers Beware
Old 12-07-2009, 12:59 PM
  #21
Derf00
Gentleman's Relish
Derf00's Avatar
ahh the advantages of living in AZ (clean underside) My 08 looks almost as good after 18 months driving in AZ
Pumpkin jackers...DOH lucky ou didn't crack the casing.
Derf00 is offline
Old 12-07-2009, 03:11 PM
  #22
157dB
Cut & Paste Expert
157dB's Avatar
Originally Posted by Riptide
This is what happens when you aren't CAREFUL. The only way that cover gets pinched is by putting the saddle under it. The saddle should go slightly behind it and not be touching the edge of the cover.
Heck, with that thinking, I could jack it up by the fender
sheetmetal as long as I was CAREFUL.
If you jack it properly, and dont take shortcuts, you dont have to be careful.
One less step just so you can do both sides at once.
Lazy forkers....
157dB is offline
Old 12-07-2009, 03:14 PM
  #23
Riptide
Riptide's Avatar
Originally Posted by 157db
Heck, with that thinking, I could jack it up be the fender
sheetmetal as long as I was CAREFUL.:
Except for the critical fact we aren't talking about jacking up a fender.
The diff will be fine if you're careful.
Riptide is offline
Old 12-07-2009, 03:41 PM
  #24
hammeron
hammeron's Avatar
the same old battle lines are drawn and
the usual suspects are dug in. lol
i'm not taking sides.....just watching the show.
hammeron is offline
Old 12-07-2009, 04:17 PM
  #25
jahudso2
jahudso2's Avatar
I jack my pumpkin like it owes me money
jahudso2 is offline
Old 12-07-2009, 08:12 PM
  #26
pascal
S197 Section Modder-ator
pascal's Avatar
Anyone can fugg anything...
So yeah, if you try hard enough, you will (no offense OP).
I jack zee pumpkin successfuly for more than 30 years now and I'll only stop when I'm dead.
pascal is offline
Old 12-07-2009, 08:20 PM
  #27
Rubrignitz
Rubrignitz's Avatar
I jack mine from the pumpkin all the time. No problem. Whats up with that diff cover that comes all the way down to the housing?? My swaybar is somewhat in the way but you can see that I have about 1/2-1'' clearance between the cover and housing bottom.
Rubrignitz is offline
Old 12-07-2009, 08:23 PM
  #28
pascal
pascal's Avatar
My take is that the car slid and the jack caught that lip...
pascal is offline
Old 12-07-2009, 08:28 PM
  #29
Rubrignitz
Rubrignitz's Avatar
I had a merc capri 5.0 when I was 16. Ran over something in the road and damaged the cover like that...musta lost all the fluid. Was rolling through a neighborhood at ~30mph and baarrrrkkkkkk!!! sucker locked solid as I ground to a halt lol.
Old 12-07-2009, 08:31 PM
  #30
pascal
pascal's Avatar
Damn, must have been epic!
Those 5.0 Capris were cool.
pascal is offline
Quick Reply: Pumpkin Jackers Beware
