Sponsored by:
Sponsored by:
Pumpkin Jackers Beware
Old 12-06-2009, 10:27 PM
robs
robs's Avatar
Default Pumpkin Jackers Beware
Alas... I've been a hard core pumpkin jacker. Now I see why you ain't suppose to... Crap...
Oh well.. I've been hearing the "ratchet" from the limited slip around corners. Guess it's time to swap out the clutch discs anyway..
robs is offline
Old 12-06-2009, 10:28 PM
2007CalSpec
2007CalSpec's Avatar
You really jacked up that rear! Pun intended.
2007CalSpec is offline
Old 12-06-2009, 10:42 PM
Diabolical!
Diabolical!'s Avatar
Hi. I'm a pumpkin.
Diabolical! is offline
Old 12-06-2009, 10:44 PM
jahudso2
jahudso2's Avatar
If you absolutely have to jack from the pumpkin, why not jack from the part where the sticker is? It is much more flat and it is all solid with no flimsy covers to bend.
jahudso2 is offline
Old 12-06-2009, 10:53 PM
Boozshey
Boozshey's Avatar
Did you use a block of wood? Or just jack to casing?
Boozshey is offline
Old 12-06-2009, 11:43 PM
6-Speed
6-Speed's Avatar
Did you just bend the cover with the jack or was there more damage to the differential casing?
My jack has a flat saddle with a rubber pad. I also put a small towel on the saddle to provide additional cushion.
The bottom lip of my differential cover does not cover as low to the case as yours.
6-Speed is offline
Old 12-06-2009, 11:51 PM
Cal26Stang
Cal26Stang's Avatar
thats a pretty rear end 6-speed
Cal26Stang is offline
Old 12-07-2009, 12:08 AM
washamur
washamur's Avatar
^^^ Holy Crap! Did you just roll that off the factory floor?? Man that's clean!
washamur is offline
Old 12-07-2009, 12:16 AM
Buckshot Barry
Buckshot Barry's Avatar
6-Speed, how many miles is on that puppy?
Buckshot Barry is offline
Old 12-07-2009, 12:30 AM
luvmygt
luvmygt's Avatar
I am amazed at how clean that is. And if i cleaned mine, im sure it would not look the same :-(
luvmygt is offline
Quick Reply: Pumpkin Jackers Beware
