Sponsored by:
Sponsored by:
Hood lifting at high speeds.....
Old 12-13-2009, 11:38 PM
Roy_R
Roy_R's Avatar
Default Hood lifting at high speeds.....
At about 120+mph, the hood on my 2008 Stang lifts about 1inch higher than the front fenders....any of you guys seen this, looks like that hood may snap off at any minute???
Roy_R is offline
Old 12-13-2009, 11:49 PM
Black_N_Blown
Black_N_Blown's Avatar
yeah mine tends to do that as well at speeds,but never an inch it does shake around a lot tho
Black_N_Blown is offline
Old 12-13-2009, 11:52 PM
FastDEW
FastDEW's Avatar
1 INCH!! Wow, nope had mine to 130 MPH and it doesn't lift a bit as far as I can tell.
FastDEW is offline
Old 12-14-2009, 01:39 AM
SkyWitit23
SkyWitit23's Avatar
Stupid of me to say this, but you sure your hood is latched down? cause mine did that on the highway and when i pulled over to look my hood wasnt latch down all the way...idunno how it got like that either lol whoops..
SkyWitit23 is offline
Old 12-14-2009, 01:43 AM
Redfire_07
Redfire_07's Avatar
mine tends to shake a little at higher speeds but not lift like that, if its shaking tighten the rubber stoppers on the front where the hood rests
Redfire_07 is offline
Old 12-14-2009, 07:29 AM
yc420
yc420's Avatar
Mine shakes but I don't think it lifts a whole inch? How can you tell it's a whole inch when you're traveling 120+?
yc420 is offline
Old 12-14-2009, 07:36 AM
pascal
S197 Section Modder-ator
pascal's Avatar
The shaking is common but to lift 1 inch is rather severe.
Check your latch mechanism, some ain't right...
pascal is offline
Old 12-14-2009, 11:18 AM
Roy_R
Roy_R's Avatar
Hood is latched down properly....it's the side edges of the hood that lifts above the fenders. Doesn't look very safe at all. Will try to lift it manually tonight to see how much flex there is....
Roy_R is offline
Old 12-14-2009, 02:10 PM
bigray327
bigray327's Avatar
My stock hood and my Trufiber GTS-III hood both shook like crazy at high speeds. Hood pins fixed both.
bigray327 is offline
Old 12-14-2009, 02:14 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Hood lift is a problem with 05-09 S197. I believe the different design on the 2010 fixed the issue.
Anyways, Adjust the hood stops on the corners. You can also get hood pins if you're that worried about it. I have yet to hear of someones hood flying off. Shaking yes.
Derf00 is offline
Quick Reply: Hood lifting at high speeds.....
