Hood lifting at high speeds..... - Page 3 - MustangForums.com
Sponsored by:
Sponsored by:
Old 04-26-2012, 10:41 PM   #21
808muscle
808muscle's Avatar
When I'm at over 100 mph, my eyes are on the road.....way up ahead!!! LOL
808muscle is offline   Reply With Quote
Old 04-27-2012, 12:04 AM   #22
MadStang40
MadStang40's Avatar
Holy thread resurrection, Batman!
No flutter here, stock hood and fiberglass cowl. A hood flying up on my windshield is the least of my worries.
MadStang40 is offline   Reply With Quote
Old 04-27-2012, 06:36 PM   #23
bloodybobber
bloodybobber's Avatar
Default Hood lifting at speed
SpectorV on another forum said he had a friend that had the outer panel seperate from the lower and crash the windshield. The latch and hinges are attached to the bottom side. hood pins are sounding better all the time.
bloodybobber is offline   Reply With Quote
Old 04-27-2012, 11:04 PM   #24
bloodybobber
Default hood lifts at speed
From other forums I have heard of outer hood seperating and crashing windshield and a recall on earlier mustangs for hood seperation problems. I am trying to find out if the only thing that holds the OEM aluminum hoods together is the fold on the edge. I have seen steel hoods spot welded and folded on the edge and some with glue or sealer on middle bracing. I don't have access to my original hood to compare with what I have now from collision repair.
Old 04-28-2012, 12:13 PM   #25
Alec
Alec's Avatar
Mine flutters and it drives me nuts. Might go with a set of hood pins for peace of mind but really don't want to
Alec is offline   Reply With Quote
Old 04-28-2012, 12:27 PM   #26
Diabolical!
Diabolical!'s Avatar
When I'm crossing the traps at the drag strip, my hood floats so high I'm scared it's going to rip off. I'd say an inch is entirely possible, and it definitely puckers my butt every time. On a positive note, 200ish passes at the strip haven't ripped it off yet.
Diabolical! is offline   Reply With Quote
Old 04-28-2012, 12:30 PM   #27
Diabolical!
This is my buddy's 2011 GT500 at the strip. Check out the hood after he crosses the traps. Scary as hell.
http://www.youtube.com/watch?v=v5BWy...feature=relmfu
Old 04-28-2012, 01:50 PM   #28
bigblue95z
Quote:
Originally Posted by bigray327 View Post
My stock hood and my Trufiber GTS-III hood both shook like crazy at high speeds. Hood pins fixed both.
Recessed set? Or regular. I've got the recessed type and the tiny rod that is used to latch to the pins has got me worried to push a top-speed run.
bigblue95z is offline   Reply With Quote
Old 04-28-2012, 03:08 PM   #29
CaptainRon
Quote:
Originally Posted by Roy_R View Post
At about 120+mph, the hood on my 2008 Stang lifts about 1inch higher than the front fenders....any of you guys seen this, looks like that hood may snap off at any minute???
That's a very common issue with the S197 body styles. Speaking from experience the best solution is to add in a set of quality hood latch pins. The 2011+ body style is a little bit more aerodynamic. They don't call the '09's- a brick for nothing!
If you really want to go at it then ditch the OEM front bumper for a Roush style and ditch the rear spoiler for a Roush or Steeda style spoiler and you'll feel the car sucking downward the faster you go.
CaptainRon is offline   Reply With Quote
Old 04-28-2012, 09:59 PM   #30
luckydawg003
luckydawg003's Avatar
My last mustang had this issue when going over 100, its because air gets caught under the front lip of the hood that overhangs over the headlights. Try adjusting the rubber hood pieces and if that doesn't work then get hood pins, or just live with it or just drive slower.
luckydawg003 is offline   Reply With Quote
Upgraded PaulH2 Members Rides and Car Show Section 20 01-31-2016 10:48 AM
1994-1995 ODBII Port Urambo Tauro 5.0L (1979-1995) Mustang 6 10-05-2015 10:37 PM
Chassis wiggle when off throttle? UrS4 S197 Handling Section 10 10-03-2015 07:23 AM
Clear codes on '94 sn95 BOB ROME 5.0L (1979-1995) Mustang 2 09-28-2015 12:10 PM
V6 Project Problems ThatJuanStang V6 (1994-2004) Mustangs 4 09-25-2015 09:01 AM
100mph, 1986, bounce, flying, gt500, highway, hood, lifting, mustang, open, rubber, speed, speeds, stops, trufiber, vibration
