exhaust keeps coming loose - MustangForums.com
Sponsored by:
Sponsored by:
Old 12-19-2009, 03:10 AM   #1
Shadow7874
Default exhaust keeps coming loose
Put on some boom tubes about a week ago and once again one is rattling. Ive tightened both once but i dont know if im getting them tight enough. If i take them to an exhaust shop to have them weld them in place will i encounter problems when i install headers in the next few weeks? Or do any other members with boom tubes know a secret i dont as to how to get them to stay in place.
Shadow7874 is offline   Reply With Quote
Old 12-19-2009, 07:06 AM   #2
dstang10
Do you know if its your clamps coming loose? It could be the exhaust hangers touching something to cause a rattle. Look under the car when its rattling to see where its coming from. I had the exhaust hangers touching the actual hanger, and it was rattling like crazy.
Quote:
dstang10 is offline   Reply With Quote
Old 12-19-2009, 08:24 AM   #3
Nuke
Nuke's Avatar
A clamp on one side of my Stingers kept loosening up after a few hindred/thousand miles despite constant retourquing. A U-clamp from a local autoparts store solved that problem.
Nuke is offline   Reply With Quote
Old 12-19-2009, 10:10 AM   #4
bigray327
bigray327's Avatar
I welded a set of Flowmasters on, once. Big mistake. About 30 seconds later, I decided to go with another setup, and had to cut them off. Nobody wants to buy cut-off mufflers, and it's a bitch to clamp new mufflers to cut-off over-axle pipes.
bigray327 is offline   Reply With Quote
Old 12-19-2009, 11:22 AM   #5
rdsx18
Quote:
That's exactly what I was thinking. Happened to me and it was so annoying.
rdsx18 is offline   Reply With Quote
Old 12-19-2009, 12:29 PM   #6
05 Mustang
had the same issue with my 2005 GT and I ended up taking it to a local muffler shop so they could tighten all the connections down with their air tools....after that I never had any more problems
05 Mustang is offline   Reply With Quote
Old 12-19-2009, 12:40 PM   #7
loudnlow
loudnlow's Avatar
Muscle up and tighten the holy bejesus out of them.
loudnlow is offline   Reply With Quote
Old 12-19-2009, 02:26 PM   #8
Shadow7874
Quote:
Ill try this
I was worried about over torquing them but i guess thats not as easy as i though.
And i havent check elsewhere for rattles but the first time it occurred it was the clamp allowing the muffler to slide of the midpipe.
And i dont think ill be switching exhaust any time soon
Old 12-20-2009, 07:15 PM   #9
Shadow7874
Well the clamps were a bit loose again so i fixed that problem but after some driving today ive got an insanely annoying rattle again. Everything seems tight and i cant tell where the rattle is coming from but it sounds like its higher up the mid pipe or above the muffler??
Anyone had a similar problem? its driving me crazy
Old 12-20-2009, 07:52 PM   #10
05 Mustang
sorry to hear you still have an annoying rattle shadow...
when you were tightening all the connections were you able to get a good look at everything under the car to make sure there were no areas where there might be some metal to metal rubbing??
My 5.4 4 valve Swap begins... 2002 GT Gary Ugarek 4.6L (1996-2004 Modular) Mustang 63 12-11-2015 02:01 PM
Did a few mods this summer... drfister 2005-2014 Mustangs 9 09-04-2015 07:47 AM
White smoke gone, now grey smoke. overnight89 4.6L General Discussion 6 08-22-2015 09:02 PM
91 5.0 mustang Clunking in rear end? Exhaust leak? 91StangOwner 5.0L (1979-1995) Mustang 5 08-20-2015 11:34 PM
2004 v6 Rumble/Shake on startup Itstbrown V6 (1994-2004) Mustangs 1 08-09-2015 03:49 AM
2005, bassani, clamp, clamps, coming, exhast, exhaust, ford, gt, hangers, loose, loosening, magnaflow, mustang, rocker
