Steering Wheel Swap - Page 12 - MustangForums.com
Old 05-09-2010, 05:45 PM   #111
2010V6Stang
BEWARE! Possible Scammer
2010V6Stang's Avatar
SO how long did the swap take everyone and how/what did you do?
2010V6Stang is offline   Reply With Quote
Old 05-09-2010, 06:18 PM   #112
dstang10
Took about 20 minutes of actual work.......pretty easy disconnect battery let it sit for roughly 30 minutes. take out center of the steering wheel(airbag) by removing the bolt on each side. Take the center bolt out, remove wheel. Install in reverse order..I did torque the center bolt.
dstang10 is offline   Reply With Quote
Old 05-09-2010, 08:59 PM   #113
2010V6Stang
What did you torque the center bolt to?
Old 05-09-2010, 09:46 PM   #114
dstang10
Quote:
41 ft lbs
http://www.2005stang.com/gallery/alb...eringwheel.pdf
Old 05-09-2010, 09:54 PM   #115
JWButler14
JWButler14's Avatar
same here, about 20mins and 41 ft lbs.
JWButler14 is offline   Reply With Quote
Old 05-09-2010, 10:22 PM   #116
2010V6Stang
On those instructions it is saying to pop off the center, Which is the airbag I guess. Is that correct? Where are the two bolts on the side? Under the airbag?
Old 05-09-2010, 10:48 PM   #117
dstang10
There are to black caps on each side right in the middle of the center part of the wheel. Pop those out with a screw driver and then the bolts will be exposed. Make sure you disconnect the battery and make sure the power is fully discharged out the system. Last thing you want is an airbag blowing up in your face.
Old 05-10-2010, 09:13 AM   #118
incorrigible
incorrigible's Avatar
This thread has a step by step procedure for the wheel swap.
incorrigible is offline   Reply With Quote
Old 05-10-2010, 09:38 AM   #119
2010V6Stang
Very nice^^^^ This is cake lol
Old 05-10-2010, 02:19 PM   #120
JWButler14
JWButler14's Avatar
Anyone have any luck getting the audio controls to work yet?
Wheel Question! (New member, hi folks) Tivo304 New Member Area 4 12-05-2015 09:46 PM
AFTERMARKET STEERING WHEEL INSTALL BOBCATJACK New Member Area 3 09-14-2015 03:18 AM
trans swaps 97SN95GT 4.6L (1996-2004 Modular) Mustang 4 09-13-2015 10:45 PM
Steeda & Nitto Tire Testing NT555 G2 - Great Photos Inside!! tj@steeda Steeda Autosports 0 09-08-2015 12:50 PM
HELP.. Should I buy this fox? raleigh05GTO New Member Area 5 09-04-2015 08:09 AM
05, 2000, 2010, bars, bolt, forum, gt500, install, mount, mustang, replacing, steering, strano, swap, sway, wheel
