Remote Start for Manual Transmission???
#21
While Iīm not convinced itīs really a ĻbadĻ idea, since the only real reasoning for it by most is one guy with it poorly done as an example, then everyone being shocked by that fact.
Seems to me thatīs rather like someone posting about how they were in a head-on collision due to their cruise-control because the person that installed it didnīt tie turning it off with the brake-petal, and therefore itīs a bad idea to have cruise control.
Normīs post being the only exception so far, I donīt ĻneedĻ to have it, so Iīll just deal as I have done in the winter.
I do recognise that should the em-brake have an issue it could become bothersome to manual disable, or it would then be a safety issue, so possibly not worth the hassle a few years down the road just so I donīt have to step outside in the morning, then run back in. *shrug*
But thanks all!
#22
I realize that it is possible to do this (R/S in a MT car). Have those of you who want to do this specific mod ever seriously questioned whether or not you actually should? If not, why not?
Norm
#23
I do think the risk in this case is far overplayed, again, so long as you get it installed right. Much the same case as having Jimmy-billy-bob across the field do your rear-differential and having the gears seize at the dealership, and trying to blame the dealership for it.
#24
They are not mechanical at all and require no physical contact to work.
They have been tested to billions and billions of cycles without fail.
Its been told before of how to do a neutral start switch before many a time.
Not that I would recommend it.
Search 'my mustang is in the lake across from the dealership'.
How many people here actually HAVE a remote start with M/T ? I read a lot of posts saying its horrible and dangerous, but who actually runs it ?
I do, It is pretty fail safe unless someone crawls into the car with a window down and puts it in gear when the engine is off ( read below ).
I have a compustar and in order for it to remote start i must :
Come to a complete stop.
Put car in neutral.
Put car in neutral.
Or did someone else do the install?
I have my starter wire hot all the time and the only time
the starter actually turns is when the key is in the run position,
the engine is not running and the clutch is fully depressed.
Its like a dash mounted start button but $100 cheaper.
If I stall her at a light, the engine restarts instantly when
the clutch is depressed. Very neat modification and I believe
I am the only one with it.
I can never understand how the neatest electrical mods are not
used widespread among forum members...
Mine is heavily modified unlike most.
I guess most dont understand the electrical aspect
and only comprehend the mechanical aspects of the S197.
#25
These kinds of modifications are the only ones I'm comfortable with my electronics and computer background/work.
The other modifications I've done to my own I've hired someone else to do that I knew could do it right. Ie. The recessed rear louver replacements (shop specializing in car windows), and a sub-shop from the dealership to do the rear diff.
Anything electrical I don't trust anyone else to do aside from myself. Sure as heck not the local audio/car-alarm shop with crimp connections other various rather rude things I'd have to say about the average one.
See this for details on the car-pc I've used for 2+ years in my stang.
And this and this for an even better recent model with an Ipad done.
#26
A lot of us see involving this sort of electrical aspect as needless complexity when the basic task (starting the engine, in this case) has no functional reason to incorporate it and where doing so can detract from vehicle capability or add restrictions to its operation. IOW, K.I.S.S.
Norm
#27
Or completely trust it. Electrical things aren't terribly functional after somebody or something lets all the magic smoke out, and you don't ever seem to get much warning about the smoke escaping until after it already has.
Norm
Norm
The only reasons I won't be doing it is that if there is a potential issue with the em-brake not being tightened down properly at a regular maintenance interval it becomes a potential nuisance as I'd have to disable the remote-starting capability until fixed. Or the simple reason that going through all this trouble to bypass the immobilizer, then wire everything else up properly just isn't worth it personally to me for just simplistic remote-starting. If I were doing a full alarm install, it'd be a different story. I like to get more bang for my buck if I have to tear into my car for a mod.
#30
remote starting isn't all about winter driving. living in AZ where it gets to 115+ during the summer it'd be nice to get into a car that the has had a chance for the ac to cool down the interior, espically with leather seats.
E
E
