Sponsored by:
Sponsored by:
Installing subs and amp to stock navi
Old 01-02-2010, 08:11 PM
JBALLOY08GT
JBALLOY08GT's Avatar
Default Installing subs and amp to stock navi
Hey I'm getting ready to install 2 10'' kicker l5's with a Rockford Fosgate 800 2 channel punch. I will buy a new amp kit, twisted RCA cables, Rockford Fosgate 1 farad cap and LOC converter since I will be using my stock navi. My question is should I tap into the door subs so I don't loose any power to the rear speakers for the LOC or is there a better location? Any tips are advice is appreciated!
JBALLOY08GT is offline
Old 01-02-2010, 11:28 PM
Lethaldosage423
Lethaldosage423's Avatar
i just went in through my Rear speakers
i used a High to Low converter and its mounted on the roof of my trunk between the two rear speakers
sounds good to me
Lethaldosage423 is offline
Old 01-03-2010, 09:21 AM
Formula
Formula's Avatar
I was looking into this for my fiances car and found this:
Audio Interfacing
That should work and give you the best quality sound. I haven't tried it yet, but you could call them and make sure.
Formula is offline
Old 01-03-2010, 10:13 AM
rford426
rford426's Avatar
When I had my solobaric in my trunk I couldn't get the solobaric and the door subs to both work at the same time...Do you need a y splitter for the two?
rford426 is offline
Old 01-03-2010, 12:56 PM
JBALLOY08GT
sounds good to me
So you tapped into the rear speakers than from there straight to the amp which kind of LOC did you use and what did you to tap in to for the remote power?
Old 01-27-2010, 04:03 PM
SikO7GT
SikO7GT's Avatar
I also wanna add an aftermarket amp and 2 12s so from what i've gathered is you need a locb.2 and tap into the rear speakers!! For the turn on lead the easiest way i've read to do it is to buy fuse taps and use fuse #5 which becomes hot when the ignition is on!!
I'm totally new to the whole audio system thing so just research this up and hopefully I pointed you in the right direction!!
SikO7GT is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
toastintx64
08-29-2015 05:12 PM
pjrolvrz
08-10-2015 02:10 PM
pjrolvrz
08-10-2015 01:39 PM
Quick Reply: Installing subs and amp to stock navi
