bonehead left key on
What the heck kind of battery cable hookup is in this 06 GT? I went and left the key on after down loading a tune, now my battery is flat! ....OK I'll say it, I can't figure out how to take these wires off without feeling like I'm having to over work the issue.....is it really that simple that my sofisticated mind can't lower itself to that level or what?
I called the "dealer" he states with a (long pause) that charging the car with the battery installed is not a good idea...I don't like ideas, I need facts, when it comes to something that can become pricey. anyone have factual knowledge?. I can't find any online,,,,
P.S. what the **** was wrong with the method???
Aloha,
Aloha,
if you are asking how to disconnect the battery
cables, there is a nut that you loosen. i think
it might be 5/16 or somewhere around that.
you loosen the nut until the clamp is loose, then
you wiggle it and lift it up off the battery post
at the same time.
hope this helps.
disconnect the negative side first, then the
postive side. when hooking back up, reverse
the order.
at the same time.
hope this helps.
the order.
As far as charging is concerned, it's better on these cars to charge with the battery disconnected since most chargers deliver "dirty" power whcih can screw with or destroy electronics. However, a quality charger including some of the better trickle chargers (Battery Tender, for example) are supposedly relatively clean (both my GT and the g/f's Stangs are in storage with Battery Tenders connected and the batteries NOT disconnected).
What I meant about the method was, couldn't the SIMPLE old style of clamps accomplish the same results? enginners have to justify thier salary I guess.....
I've never really trusted those things. The wiring on the power port is pretty thin, and I don't believe it could take a lot of juice if needed. Sometimes I have seen the jumper cables get hot when doing a jump. It depends how much power is being drawn through. I would rather have jumper marks on the battery terminals than have toasted wiring inside the dash.
