Still trying to fix a vibration in the wheel
You need hub centric rings to make sure that the wheels are completely centered on the hub. Even if you properly torque the lug nuts in the proper pattern the wheels can still be slightly off causing a vibration at higher speeds.
-Jeff
-Jeff
Another option is to have the wheels balanced while installed on the vehicle, which balances the entire rotating assembly. The bad part is finding a shop with this type of equipment, and obviously the extra $ to have it done.
Well, its either put the weights behind the spokes or have them hammered on the face of the wheel! But the scratches still suck.
Did you ever fix this? I have been fighting the same problem since the day I bought the car (dealer had fitted aftermarket wheels). They have changed the tires, balanced them 3 times, replaced the spacers that go round the hub and even road force balanced them.
Bizarrely, the problem comes and goes (about same speed range you said). My current theory is the TPMS is sliding around the wheel making the balance go in and out as it moves away from the position opposite the group of weights required to balance it. (this theory was spawned because one of the TPMS bands came completely uncoupled, clattering around inside the tire - I have simply removed that one (and now have the annoying fault light on the dash).
Any thoughts out there? BTW: the dealer has refused to keep working with me on this problem which really sucks on a car that I love and i less than a year old but has this stupid vibration coming and going.
I did finally get it fixed with a Road Force balancer. It took a long time. I did have the clips removed. Even after that there is still a minor tremor in the wheel at around 55mph. One of the TPMS sensors that was mounted by Cruzin Concepts does not work (never did) so I'm not sure if that's causing the problem. I'm actually taking it to the dealer on Friday to see if I can get this taken care of. I'll let you know if it was loose and causing a vibration.
Same boat. Had them balanced twice and then Road Force balanced and still the same problem. I also had the rings removed from the rotors from a previous brake job as well as installed the hub centric rings. After 2 weeks I finally gave up and returned them. After many theories, I think the vibration was caused by too small of a hub fit. The correct hub wheel size is 5x114.3 while the aftermarket wheels I bought were 5x100. I think this was my culprit. Sure they fit great with the hub rings. Yea, the were balanced perfectly 3 times but they just would never be right since the center hub bore was smaller than stock. Here's my thread on them, start at post #15:
http://www.allfordmustangs.com/forum...els-put-2.html
and my thread on this forum:
https://mustangforums.com/forum/2005...ew-wheels.html
Thanks guys. I had removed the snap rings early on (after reading older posts), I also ensured the wheel spacers are installed properly (required on these American Racing wheels because they are a bit oversized at the hub), had the wheels balanced multiple times and road force balanced. Still the vibration comes and goes in the approximately 60mph range.
Follow the S197 Workshop manual for TPMS system troublshooting procedures...
Omgitsa88Stang
10-05-2015 07:33 AM
