My long awaited build... (I don't think 56k exist anymore) So lots of pics...
So as much know I have been stock piling parts while I was deployed. Well here's the list and the start of the build...
I will try and continue to take pictures as I go along. Not all parts are pictured as I may have forgotten or have not made it through the mail yet.
Engine
-Saleen Supercharger
-Supershaker Conversion
-AFCO Heat Exchanger
-BGG 8-Rib kit with 3.2" Pulley
-Moroso Intercooler Battery location tank
-2 - Moroso breather cans
-Comp ***** Thumper Cams 127020
-Comp Phase Limiters
-1 Step Colder Plugs
Fuel
-Aeromotive Fuel Rails
-Misc hoses and fittings for fuel rails
-#60 Injectors
-GT500 Fuel Pump
Transmission
-Spec 3+ Clutch
-Fidoza Flywheel
-CHE K-Member Brace with torque limiter
Brakes
-BAER Decelerator rotors for all four wheels
-HAWK HPS Pads
Suspension
-BMR LCA Relocation Brackets
-BMR LCA
-BMR Adjustable UCA
-BMR Adjustable Panhard Bar
Looks
-SHR Black Fuel Door
-Black Upper/Lower Billet Grille (Pony Delete)
-1969 Grille Emlbem (Not Remake)
-CDC Aggressive Chin
-Open headlight bucket mod
-Powder coated cam covers
Interior
-White face gauge overlay
-MyColor Cluster
-LED's for interior color change
-Autometer Dash Gauge Pods
-SOS 3 Pillar Pod w/shift light mount
-Raptor shift light
-5 - Phantom II gauges; boost, fuel pressure, oil pressure, oil temp, water temp.
-AEM Wideband Air/Fuel
Exhaust
-Kooks Headers
-Kooks Catted H
-Stage 8 locking header bolts
Misc
-JDM Tune
-SCT 3
-Trunk mounted battery box
-Poly Motormounts
-Canton Power Steering tank
-Supplies to move all wiring out of engine bay
-Move PCM and Fuse box to glove box
Engine
Fuel
-#60 Injectors
-GT500 Fuel Pump
Transmission
-Spec 3+ Clutch
-Fidoza Flywheel
Brakes
-HAWK HPS Pads
Suspension
-BMR LCA
-BMR Adjustable UCA
Looks
Interior
-MyColor Cluster
-Raptor shift light
Exhaust
-Kooks Headers
-Kooks Catted H
Misc
-JDM Tune
-SCT 3
-Poly Motormounts
HERE COMES THE PICS....
Engine
Fuel
Transmission
Brakes
-HAWK HPS Pads
Looks
Interior
-MyColor Cluster
-Raptor shift light
Engine
Fuel
Transmission
Brakes
-HAWK HPS Pads
Looks
Interior
-MyColor Cluster
-Raptor shift light
Exhaust
-Kooks Headers
-Kooks Catted X
Misc
-JDM Tune
-SCT 3
-Poly Motormounts
-Canton Power Steering tank <-still gotta buy
MISC Parts and Supplies...
-Kooks Headers
-Kooks Catted X
Misc
-JDM Tune
-SCT 3
-Poly Motormounts
So yesterday I spent the day taking a lot of stuff apart. There was a problem with the original blower I bought so I had to wait to find another. JDM has sense shipped out the new blower and should be here in the next week. So in the mean time I prepped everything and did other things that would be needed.
I started the day off by removing the CDC Shaker and CAI. I had presold those items and the buyer was coming by to get them. Once that business was taken care of I then made the goal to get the CAMS and phase limiters installed.
Everything went pretty straight forward and was not as hard as expected. Just take your time if you have never done it before and it will all make sense once you get in there.
Here are some pics of the progress. This not a DIY thread nor was I going to make one. There are plenty out there that are helpful and a waste of my time to mimic just another. But if you have questions about anything along the way please feel free to ask.
I found that by cutting a hole in the hood allowed me to hook a light up. Seemed more practical to cut a hole than to take off the hood.
Alot of wires disconnected and fuel line removed.
I removed the intake now because it allowed more room for the cam install and since it will come off for the Saleen Blower then why not now...
Removed Cam Covers.
I tried to use this POS tool but it wouldn't compress the springs far enough and I got mad so I didn't use it. I just back the bearing caps off slowly like half the other guys.
Bearing caps off.
Phaser and Sprocket removed awaiting the COMP Phase limiters.
New ***** Thumpers installed...
Temp cam covers... just to keep dirt out.
Removed Cam Covers.
Bearing caps off.
