add SYNC to 2011 base model - Page 10 - MustangForums.com
Old 05-08-2014, 09:38 PM   #91
crazietj
Ok. I have everything to do the install. From reading what you posted. DO NOT hook up the red wire because the module gets its power from the premium ACM right? What about the 2 other wires. The white and and white and blue stripe?
crazietj is offline   Reply With Quote
Old 05-09-2014, 11:08 AM   #92
crazietj
Quote:
After looking at the 09 installation info from parts express it is supposed th go the the diagnostic port. Did you guys splice them into that?
Old 05-10-2014, 07:39 AM   #93
redrocks
Those are connections to the CAN bus (high speed, IIRC). Not needed for normal operation, but I think it is needed if you do module programming. While testing, I ran with mine disconnected for a while, then made the splices when I finished up. Didn't notice any difference in operation. (My sync module(s) were from wrecks--pre-programmed.) The workspace to do those splices is a little tight--a bit of a pain.
Good luck!
redrocks is offline   Reply With Quote
Old 05-10-2014, 08:25 AM   #94
awoychosky123
awoychosky123's Avatar
Quote:
Good luck!
Yea I know what you mean first time I hook mine up one of the DlC wires broke and the PAT came on, I was pissed! But eventually it worked.
awoychosky123 is offline   Reply With Quote
Old 05-10-2014, 09:48 AM   #95
crazietj
Thanks.
Old 05-11-2014, 09:17 PM   #96
crazietj
Well I got it all in. But the voice button isn't working. I didn't hook up the red wire. So I wonder if it does have to be hooked up. Or its the mic. I took out the factory mic out of the overhead lights and put the one that came with the 09 kit it in its place. I ran out of time. I have tomorrow off too. So ill be digging into it tomorrow. Any thoughts? Of what it
Old 05-11-2014, 11:05 PM   #97
crazietj
So i ran the 2 wires from the switches down to the hmi plug. Cut the 2 that are to go to pin 4 and 6 and spliced them in. I double checked the wires. And everything seems good. I'm not sure why they are not working. Unless it's because the sync module is fro a 13? But I would think the wires are still the same.
Old 05-12-2014, 07:16 AM   #98
awoychosky123
you have to get a pre programmed module or get it programed happened to me as well.
Old 05-12-2014, 07:51 AM   #99
crazietj
Quote:
It is its from a wrecked 13
Old 05-12-2014, 09:44 AM   #100
crazietj
I am thinking it needs programmed. I wonder if the acm came from a non sync car. The volume and source buttons work. I just can't get the voice or phone to work. I don't have any dealers around that will reprogram the acm. So it looks like I'll be looking for another acm.
2010 Mustang GT, Supercharged, 8700 miles, SE Pennsylvania Galactic Mustangs For Sale 8 08-28-2016 06:39 PM
Hello from South Florida fcarpio New Member Area 16 04-30-2016 06:31 AM
My idea of Best Bang for Your Buck Car. What do you guys think? mungodrums 5.0L GT S550 Tech 7 10-07-2015 05:01 AM
All 10-14' Mustangs w/ Sync Raxiom Navigation Unit - Not Working - yourmom6990 Parts For Sale 2 09-14-2015 11:52 PM
2010, 2011, add, adding, base, cost, electronics, ford, gt, labor, mustang, package, premium, sync, vehicle
