New clutch stuff neeed help
Centerforce Dual Friction Clutch set #DF490309
National Bearing #F33126 (Clutch Pilot Bearing)
DORMAN Part # CS650109 (Clutch Slave Cylinder/Throwout bearing)
These are the parts is there anything i have to watch for when installing them? Any fit problems thanks
Last year I installed a Centerforce DF. It blew the slave cylinder after about 1600 miles. Further research revealed I wasn't the only one. The pressure plate is too stiff for the factory slave.
I replaced it with a McLeod RST which has worked great since installation.
Just trying to save you from what I went through.
there's this one, but it's more of an overview
than a detailed writeup.
https://mustangforums.com/forum/4-6l...ion-guide.html
there's a few guys on the forum who have done their
own clutch, so if you have a specific question maybe
we can help.
getting the old pilot bearing out can sometimes be a
challenge. i saw a great idea on youtube, where a guy
used small pieces of wet newspaper (instead of grease)
to fill up the hole. after a few cycles of compressing
and adding more wet paper, the bearing comes out.
good luck and we are here to help.
we can help.
Ok cool I thought I read somewhere that a new slave cylinder would rub on something so you had to shave it not sure where but I'm just hoping everything will go in smooth and no fit problems I just bought a haynes manual so that will help
