Anyone running 20"s with sportlines?? please help
Im about to order these sportlines but i have a possible issue..
my rims are 20"s with a +45mm offset in the back and the rear tires are 315/35/20 AND I have 1 inch wheel spacers.
What I want to know is will it clear the wheel well?? And if so by how much?
How much clearance between the tire and the wheel well do you have because im wondering how far my tire is going to stick out with all of this. (the wheel spacer I may remove once the rims are on if i feel liek its out too far.. just waiting to see)
anyone??
anyone??
i think the tires size you got and the rims you will be out to far in the back, but when you get the rims in we can play with it and see what works. but when you lower it will be a diff story but we can meausre and see where you will be at .
either way ill be rubbing.. honestly doesn't matter if its the center of the tire or just the edge.. remember.. my tires are 315's and my rims have 45mm offset.. either way i think its going to be the SAME for me the ONLY difference is the wheel will be out more which wont make any difference if its already out passed the fender without the spacer..
