Well.....next weakest link has been found!
well kinda spendy but they come with alot, heres a few more options:
http://www.blowbyracing.com/bbr20mugttrt.html
http://www.blowbyracing.com/t56cosptrkit.html
http://www.newtakeoff.com/mustang_gt...2005-2008.aspx
When I read this thread, I thought to myself... Input shaft. Cant belive you just blew out 2nd but can still move.... Crazy
I would of thought the input shaft too.
I have a plan for when/if mine goes. Either a rebuilt 3650 with 26 spline shaft or 4r70w. I go back and forth. If it happened right now I'd go with the auto. It would mean no more clutch/slave cylinder/ changes along with flywheel surfacing. That crap is already old and I've only dropped the tranny 3 times. It wouldn't be any harder than swapping out the manual. You can have a trans brake if you want. No more notchy shifts.
Hell, I'm not even on the fence now. Auto all the way. Think I'll start collecting parts.
that sucks man but once you get that rebuilt of get somethgin else then you can really pound it good and like you said crank up the boost a little more.
what size cowl you running looks bad *** i just got a 4 inch
It looks like you are getting good advice on another forum. It would be about $4k for a complete set up like I would want, plus shipping.
Thanks for the wake up call. I'm putting a bigger pulley on mine, keeping it under 500rwhp and calling it a day.
Edit: If money is real tight just buy one from nto http://www.newtakeoff.com/mustang_gt...2005-2008.aspx and turn down the wastegate for awhile. Then as money allows send your old tranny to Liberty or wherever and upgrade the internals.
input shaft,if you look close,you can see it is tweaked,so it was real close to going,im kinda glad it was just second gear,at least i was able to get the car home.
second gear i presume?
just cause!
Found this for $3250 http://www.promotionpowertrain.com/N...8_MUSTANG.html
It's a beefed up 6060 with everything but the clutch.
Same company also sells a beefed up 3650 with a 26 spline shaft for $1650.
Damn Paul, that input shaft was ready to go as well.
Good thing you made it home...
I could be wrong but swapping to a slush box might be more costly and if left stock, you might be on burrowed time again.
Your cheaper route seems to get a reinforced 5spd though...
