where did you mount your amp - Page 4 - MustangForums.com
Old 04-01-2010, 05:18 PM   #31
kingsofcrunk
kingsofcrunk's Avatar
Adding just an amp to factory speakers is kinda pointless. I would add an amp and new speakers to start off with. You can retain your stock headunit, but will have to get a line out converter or wtf ever it's called.
kingsofcrunk is offline   Reply With Quote
Old 04-02-2010, 01:23 PM   #32
musty ruffler
Quote:
Originally Posted by alec231236 View Post
Newbish question here, considering I know virtually nothing when it comes to audio-
I have the base, single cd stereo, would an amp liven it up? Just one? Or would I have to replace speakers, head unit or add a sub woofer?
if you're going to be upgrading piece-by-piece, the biggest bang for your buck and easiest install by far will be upgrading your headunit. an aftermarket one will have a small amplifier built in (the watt ratings are usually listed in RMS per speaker). you'll have to get a wiring harness, which will tie the thing into your factory wiring; and a snap-together kit to replace the trim panel.
once you've upgraded your headunit you probably won't be able to help yourself and will crank it up to the point where you blow a couple of the factory speakers. so that'll be your next step. this is a little trickier because ford chose weird sizes (5x8 & 8", it's probably the front 5x8's that'll go first), and door speakers are annoying to get to.. but you can make things easier by getting a standard size speaker and an adapter plate (or if you're crafty, make the plate yourself out of thin plywood). be sure to replace your speakers in pairs- ie, you don't have to do all of them at once, but whenever you do one, do both sides. most speakers are sold in pairs, so this is probably obvious.
if you have the doors open, might as well throw some sound/vibration deadening material in there- dynamat is a brand name, goes on like a sticker. frost king brand duct insulation is a similar, lighter-weight material sold at Lowe's and other hardware stores- it's not as effective, but it's 1/5 the price (1 $18 roll should do both doors).
so at this point you're under like $300 and you have an entirely new, kickass sound system.
- if you feel like it doesn't have enough thump, you can pick up a sub amp + subwoofer (or a powered subwoofer if you're willing to pay a premium for simplicity); and a speaker-to-line level converter ($15 at walmart), which will get spliced into one (or both) of your rear speaker wires and then run to the amp. make sure that you take the 2 minutes to tune your sub amp to the rest of your system, so that bass hits still sound like music rather than kidney punches. note that most sub amps require running a new fused power line from the battery to the trunk. if you already have the wiring for a Shaker 1000 maybe you can tap into that?
- if you feel like the system with new headunit & speakers still lacks overall volume/ clarity or gets distorted at your favorite volume, that's when you'd want to add in a speaker amp. if you've already put in an aftermarket head unit, you'll run a set of RCA cables from there to the new amp, and you'll need to run new speaker wires from the amp back to the front speakers. if you have both sub & speaker amps, you'll use a power distribution block to split battery power, and will probably replace that line converter with a sub-out from the speaker amp.
if you haven't already seen http://www.crutchfield.com, their prices aren't the best but they have a TON of useful information.
musty ruffler is offline   Reply With Quote
Old 04-02-2010, 02:02 PM   #33
JDWalton
JDWalton's Avatar
well that amp he is looking to mount is pretty small, he can mount it in his dash behinde his glove box. I think thats where the add on amp from Shelby / Kicker mounts too.
JDWalton is offline   Reply With Quote
Old 04-02-2010, 08:59 PM   #34
Rubrignitz
Rubrignitz's Avatar
I created a "floating" mount from carpeted MDF. Provides for plenty of trunk room but blocks the hole when you put the seats down and has stymied me on many occasions when I needed to pack something longer than the trunk is wide. I'd try a "floating" mount to one side of the trunk if the amp is small.
Rubrignitz is offline   Reply With Quote
Old 09-30-2010, 09:11 AM   #35
teejay76
teejay76's Avatar
I installed mine on a rack. I don't ever need to fold my seats down, so this is what's most practical for my setup.
teejay76 is offline   Reply With Quote
Old 09-30-2010, 09:48 AM   #36
JDWalton
JDWalton's Avatar
doesnt look too bad, but usualy you dont seal off the trunk with the subs in it.... Our stangs are kind of weired anyway. Seats up or down actualy seem to make a difference where 90% of cars I have put systems in, didnt matter at all.
Old 09-30-2010, 12:33 PM   #37
boss hoss
I mounted mine on the back of the rear passenger seat.. Just drilled right into it.. I've removed it a couple of times the holes are not noticeable. That spot is also easily accessible when you need to mess with it..
boss hoss is offline   Reply With Quote
S197 Parts baddog671 Parts For Sale 20 07-26-2016 02:20 PM
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 05:23 PM
Chassis wiggle when off throttle? UrS4 S197 Handling Section 10 10-03-2015 07:23 AM
04 Mach 460 system, Installed Aftermarket HU, No Highs/Tweeters breaking Audio/Visual Electronics 5 10-02-2015 02:27 PM
Street Action Tonight Explosive Street/Strip 17 10-02-2015 08:45 AM
adding, amp, amplifier, base, bench, dash, material, mount, mounted, mounting, mustang, put, rear, tire, upside
