Sponsored by:
Sponsored by:
Kooks Longtubes installed!
Old 05-10-2010, 09:11 PM
Lupo222
Lupo222's Avatar
Location: Camp Lejeune, North Carolina and Fort Lauderdale, Florida
Sounds good!!
Only question for you: your sig says 306rwhp before the LTs...and you have cams?? Did you dyno at a high elevation or something? That sounds like what you should be making with just intake/exhaust/tuner. I just made 336rwhp with almost the same mods and my AFR is a little jacked up. Jasper made 351 with almost the same mods.
Doesn't sound quite right...
Lupo222 is offline
Old 05-10-2010, 09:14 PM
branman1
branman1's Avatar
Originally Posted by Pony Up
What she idling at??
I think Chris has it set to 775
branman1 is offline
Old 05-10-2010, 09:18 PM
branman1
branman1's Avatar
Originally Posted by Lupo222
Sounds good!!
To be honest im not sure. I know its a tad low but I have seen many others with the same mods putting down almost the same numbers. Every dyno is gonna be different considering the weather conditions calibration and all. I dont have a baseline on that dyno or any for that matter so that would really be the only way to tell.
branman1 is offline
Old 05-11-2010, 07:13 AM
branman1
branman1's Avatar
I just noticed that you dynoed with long tubes which makes a huge difference when combined with cams. Im sure once I dyno I will be right up there maybe a little less.
branman1 is offline
Old 05-11-2010, 07:46 AM
dysan
dysan's Avatar
Originally Posted by branman1
I hear ya man props to you def for doing it on your back. How can you tell you have a leak? Can you see a carbon spot someone that indicates it or?
I don't see any carbon trails but I can hear it under load. I suspect it's by the bolts that are under the engine mounts where you can't see them. I may still take care of it myself and try OEM gaskets with copper RTV on them this time.
I meant to put RTV on the Percy gaskets that came with the Kooks but I got so caught up in the install that I forgot.
dysan is offline
Old 05-11-2010, 07:49 AM
branman1
branman1's Avatar
Yeah I pulled the brackets for the motor mounts so i could get to the bolts better. It was only 4 bolts and came out easily.
branman1 is offline
Old 05-11-2010, 08:56 AM
Lupo222
Lupo222's Avatar
Ya, but intake/tune is supposed to be good for around 18-28rwhp on a stock motor and the Hot Rods are good for 30whp on a stock motor. thats almost 50whp right there, which should put you around 320whp WITHOUT the the headers....headers may throw in 15-25whp, which makes my dyno decent and jaspers awesome.
Go get it dyno'd so we can figure this thing out :-D
Lupo222 is offline
Old 05-11-2010, 01:00 PM
loudnlow
loudnlow's Avatar
That is the best sounding s197 ive ever heard.
loudnlow is offline
Old 05-11-2010, 01:10 PM
GeritGoul
GeritGoul's Avatar
get out much?
GeritGoul is offline
Old 05-11-2010, 02:19 PM
Lupo222
Lupo222's Avatar
Originally Posted by GeritGoul
get out much?
Obviously hasnt heard a LT'd Hot Rodded S197
Lupo222 is offline
Quick Reply: Kooks Longtubes installed!
