emissions with cai and tune from brenspeed
Will my 07 gt pass the emissions test in GA with the brenspeed tune? If not, could I email brenspeed asking them to make a tune that would make my car pass the test?
You have to make sure your tune has your O2's set to ready. I failed my first time because of it. So i had to go back to stock for the test. You can call or email who ever you got your tunes from and they can rewrite your tune to your O2's back on. Its mainly the rear one i believe. If your O2's are on you should have no issues.
If you can go back to stock to pass it is the easiest and cheapest way. Also depends on what you have done to your car. With my cams, LTs and all the other stuff even with the O2s on and emmissions tune it was throwing codes.
By the way BAMA is a lot cheaper for tunes than Brenspeed think $50.
Do what I did and ask Brenspeed for an emissions friendly tune. It turns the O2 sensors on and you'll pass without issue. Otherwise you probably wont pass if they plug into the OBD port. Sniffers fine though.
When I got my Bama tune I asked that he be sure to leave the O2's on and I didn't have anytrouble with emissions
here on 95 and newer they just do an obd2 diag test if the rear 02's weren't on then I'd have failed (I don't plan to lose the cats or do Lt's so I'm fine)
JDWalton
09-24-2015 08:47 PM
