help with clutch rattle
So your rattle mainly occured in neutral with the clutch out? Mine only happens when engaging the clutch while taking off. Still can't figure out what is causing it. It's good to hear that no ill effects have resulted from your rattle so far though!
It mainly rattles/chatters when going into neutral, but I have noticed it when shifting into first gear as well. No ill effects. =-)
The issue was a chewed up pilot bearing. I went ahead and installed a new clutch, replaced both the concentric slave cylinder and the pilot bearing. All has been well for a while now. Hope this help ya.
Thanks! I looked up some symptoms for bad pilot bearings... and it seems to be similar to my issue. Glad that fixed it for you! I'm kind of surprised that it's going bad at 20,000 miles, but at least it should be a relatively inexpensive repair.
did you ever figure out what it’s from or the cause? Mine just started doing it today.
I refurbished everything else but left an old fork because it looks fine and almost same rattle exist what there were before why im take cluth open in a first place.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
junior04
09-28-2015 10:53 AM
