Side mirrors not working... - MustangForums.com
Sponsored by:
Sponsored by:
Old 05-15-2010, 10:18 AM   #1
pwrl3ss
pwrl3ss's Avatar
Default Side mirrors not working...
Hi all, my side mirror controls no longer work. I checked the fuse and it looks ok. Is there any other fuse that may be tied into it? Or how else could I check to see where the problem may be?
Thanks
pwrl3ss is offline   Reply With Quote
Old 05-15-2010, 10:46 AM   #2
157dB
Cut & Paste Expert
157dB's Avatar
157dB is offline   Reply With Quote
Old 05-15-2010, 11:23 AM   #3
pwrl3ss
pwrl3ss's Avatar
THANKS!
Old 05-15-2010, 05:38 PM   #4
07blkgt62
very nice, thanks from the rest of us.
07blkgt62 is offline   Reply With Quote
Old 10-25-2014, 03:55 PM   #5
Gdaddy 23
2005 Mustang V6, both mirrors do not work. What is the fuse number to check to see if the fuse has blown for the power mirrors>
Gdaddy 23 is offline   Reply With Quote
Old 10-25-2014, 06:43 PM   #6
Nuke
Nuke's Avatar
Quote:
See #2 above.
Nuke is offline   Reply With Quote
Old 10-26-2014, 11:03 AM   #7
Gdaddy 23
Quote:
Originally Posted by 157dB View Post
Is this the reply?
Old 10-26-2014, 11:05 AM   #8
Gdaddy 23
Need a little more information than the picture. What is the fuse number in the fuse box?
Old 06-06-2016, 08:16 PM   #9
alex310
Ok I'm having the same issue, according to the diagram provided above, there is a "smart junction box (sjb) 11-1" then there is a "power distribution/sjb 13-10" then the "exterior rear view mirror switch". I will assume the "smart junction box" is the one at the passenger side. Where can I find the one labeled as "power distribution/sjb"? Fuse is good FYI. I've also tried a different switch and it still doesn't work. Thanks.
alex310 is offline   Reply With Quote
window tint issues? chrisdbassplayer 2010-current S197 Appearance Section 4 10-13-2015 07:53 PM
Chassis wiggle when off throttle? UrS4 S197 Handling Section 10 10-03-2015 07:23 AM
Rear Package Shelf jrrhd73must Classic Mustang General Discussion 2 10-02-2015 10:17 PM
I should've known better ChampInSD 5.0L GT S550 Tech 13 10-02-2015 05:55 AM
better way to attach headlights Drastang 4.6L (1996-2004 Modular) Mustang 3 09-29-2015 04:31 PM
05, 2005, 2006, 2007, 2011, 93, ford, fuse, mirror, mirrors, mustang, power, side, stopped, working
