Loud clicking noise when turning off heater/AC - Page 2 - MustangForums.com
Old 10-22-2015, 07:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Old 05-19-2010, 10:41 AM   #11
PHX8839
My car just started doing it. How much is the part and how much did you pay to get it fixed? I'll probably do it myself if I can.
PHX8839 is offline   Reply With Quote
Old 05-19-2010, 01:43 PM   #12
gatkins94
Quote:
Originally Posted by n406c View Post
Part Number
5F9Z-19E616-EA
Here you Go =)
Woohoo!!! Thanks!
gatkins94 is offline   Reply With Quote
Old 05-19-2010, 01:47 PM   #13
boochy
CSMG Moderator
boochy's Avatar
What did it cost to get the actuator replaced?
boochy is offline   Reply With Quote
Old 05-19-2010, 02:59 PM   #14
boochy
CSMG Moderator
boochy's Avatar
http://www.youtube.com/watch?v=dbE_6knb0vE
Just took a video of this, mine is doing the same thing... Only happens when I turn the car on.
Old 06-03-2010, 04:20 PM   #15
gatkins94
yep..same as mine. I have the part that the number above referenced to. It was about $20 I think....I haven't had a chance to take the dash out to replace it though, but will soon! It's annoying as crap!
Old 06-03-2010, 04:47 PM   #16
157dB
Cut & Paste Expert
157dB's Avatar
Your blend door is jumping the rack and the clicking is the result.
It probably has a lighter or some other foreign object that entered
thru the dash vent(s).
157dB is offline   Reply With Quote
Old 10-12-2010, 08:32 PM   #17
geno87
Mine is doing the same thing. How hard is it to get to it? My happened after my warranty has expired.
geno87 is offline   Reply With Quote
Old 11-30-2010, 09:57 AM   #18
gatkins94
I still haven't had a chance to take the dash out to fix this...the part just stares at me when I walk in the door.....I keep hoping someone else will do this, and take some pictures of how to replace it. I haven't done enough research on how to get to the part, so I'm hoping someone else has. I'll get it eventually.
Old 02-05-2011, 07:20 PM   #19
azrampage
azrampage's Avatar
Default Blend Door Repairs
Apparently you don't need to pull the dash apart; access through the glove box or driver's side footwell.
There are three of these.
Found this but haven't tried it yet: http://iihs.net/fsm/?dir=336&viewfil...20Actuator.pdf
azrampage is offline   Reply With Quote
Old 02-06-2011, 10:38 AM   #20
incorrigible
incorrigible's Avatar
Look like a fairly easy fix to replace the blend door actuator if you can score the replacement part. There is known issue with the gear teeth breaking off causing what you describe. To verify it's the one in the post above, disconnect the connector and start up your car. If the noise is gone, that's the one.
incorrigible is offline   Reply With Quote
2002 V6 will not start Beerman309 V6 (1994-2004) Mustangs 2 09-19-2015 02:16 AM
Upgrading to handle slicks? Info needed Dragonus18 4.6L (1996-2004 Modular) Mustang 8 09-09-2015 02:21 AM
Loud Noise Above 30 MPH bjdutch2005 2005-2014 Mustangs 8 09-07-2015 11:05 PM
Weird electrical/battery issue?? Mobiusone stang 2005-2014 Mustangs 7 09-07-2015 09:46 PM
ac, car, clicking, clincking, gears, heater, loud, make, motor, noise, noises, on, rapid, sound, switch, turning
