Friction Modifier needed for Mobil 1 75w140?
Hey all,
Do I need to still add friction modifier to the diff even though mobil 1 75w140 states that it comes with friction modifier in it? Ford calls for 4 oz of it but im not able to tell how much is already in mobil 1
I think you will find that you will be adding it after listening to your rear end cry, moan and pop when turning corners. GM rear ends seem to get by fine with synthetics and no modifier...but Fords don't. Hope I'm wrong, but from my own and a few others I've talked to.....you will need it. It's only $5.00 at Ford.
Good Luck!
Good Luck!
I dont know about the mobil 1, but I changed out the fluid a while back with RP 75-140 and my diff has been quiet, with no issues. I have heard others with after market 4.10s that have had huge issues without it however, so not sure.
I think I have to agree with the majority so far, including input from other threads on this subject. I'd add the modifier rather than wait for an issue. Or at least have it on hand so you can add it at the onset of the symptomatic noise.
