Sponsored by:
Sponsored by:
Creaking brake caliper
Old 05-20-2010, 08:15 PM
digitalcos
digitalcos's Avatar
Default Creaking brake caliper
Front passenger side caliper sounds like the hull of a pirate ship when I pump the brakes.
*Creak *Crick *Creak *Crick
It's not the pads or rotors, it'll even do it if I'm in Park. Disassembled and greased up the travel path of the pads and that made no difference. Pins seem to be traveling fine. They seem to be operating fine otherwise. Anybody else encounter this? Think it should be a cause for concern?
digitalcos is offline
Old 05-20-2010, 09:22 PM
6-Speed
6-Speed's Avatar
Did you try applying brake caliper grease to the pins?
6-Speed is offline
Old 05-20-2010, 09:54 PM
3fan
3fan's Avatar
Just a thought probably not the problem but try bleeding that caliper.
May have some air in it or dirt or some thing. You could just try cracking
the bleeder and compressing the pad with it on the car. Should'nt take
long and who knows may get lucky.
3fan is offline
Old 05-20-2010, 10:16 PM
SpartaPerformance
SpartaPerformance's Avatar
Grease the caliper slide pins, the shims that the pads contact and the back of both inboard and outboard pads.
SpartaPerformance is offline
Old 05-20-2010, 10:24 PM
digitalcos
digitalcos's Avatar
Can the pins be regreased? How do you remove the rubber boot?
That's a good idea. I'll have to give that a shot.
Old 05-20-2010, 10:31 PM
digitalcos
digitalcos's Avatar
I greased all these spots when I did the brakes a few months ago, But I only regreased the clips that the ends of the pads slide in the other day to try to stop the noise. I didn't think it could have been the shims, but I suppose I should at least try regreasing them also.
Old 05-21-2010, 08:47 AM
3fan
3fan's Avatar
I have a buddy that every time he compresses a caliper he cracks the bleeder.
Just in case of dirt or condensation. Dont want to send that stuff back in the brake line.
3fan is offline
Old 05-24-2010, 08:27 PM
3fan
3fan's Avatar
So did you work on it? Update please.
3fan is offline
Old 03-14-2011, 08:11 PM
thehotrod11
thehotrod11's Avatar
Did anyone ever figure out this problem? I have the exact same problem on mine. I've googled all over, and this is the forum I found that most closely matches my symptoms. I sure hope some one can offer me some advice.
thehotrod11 is offline
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Creaking brake caliper
