Whipple Pulley change question
I'm going from the 4.00 pulley to the 3.875. Do I need any special puller tool to remove the 4.00 pulley?.. And then I torque the new pulley to 17ftlbs correct? Anyone done a Whipple pulley change please chime in with some knowledge...
Thanks!
Thanks!
No special tool required. Loosen the 4 cap screws before taking the belt off.
I torque mine to 140 inch pounds which would be a little less than 12 ft lbs. IIRC the whipple manual calls out 125 inch pounds.
Once you do it a few times it only takes a few minutes.
Soldier GT
08-12-2015 03:46 PM
