Sponsored by:
Sponsored by:
loud low rpm engine tick
Old 09-21-2011, 12:43 PM
HOTRODD77
HOTRODD77's Avatar
Question
Originally Posted by rmssch89
It still does it, but I've accepted it as normal after meeting a few more Mustang owners that have the same issue. What you're describing sounds like the exact same thing, and if the dealer says it's normal then I guess there's nothing to worry about.
Yeah, I guess that's all we can do. At least it's documented with them in case it ever actually harms something. Thanks, that's refreshing Does yours sound like this?
HOTRODD77 is offline
Old 10-10-2011, 08:29 AM
NickyV
NickyV's Avatar
I wouldn't ignore it. I've had the same exact problem with my 07 GT/CS and ignored it. It just broke down yesterday on the interstate, and I'm thinkin it's not gonna be a cheap fix.
NickyV is offline
Old 10-10-2011, 02:06 PM
Ricardo
Ricardo's Avatar
I have the same ticking. When accelerating slowly I can hear it if I'm next to a curb or something. So far I have no codes and everything runs smooth as butter.
If it helps any I have an x-pipe and those are notorious for making a slight ticking sound from what I've read around the internets.
Also my other car (GM brand) has a confirmed leak right in front of the cats and this makes a definate ticking sound.
Ricardo is offline
Old 10-18-2011, 11:45 AM
FordService
Official Ford Rep
FordService's Avatar
Oh, I'm sorry to hear that! I hope it was a minor repair. If you haven't had it diagnosed yet, PM me your VIN and I'll review for any possible warranty coverage.
Hey Ricardo,
You may want to have the dealer inspect it, just to prevent any long-term issues. Let me know if I can help.
~Natasha
FordService is offline
Old 10-18-2011, 12:00 PM
92hatchLX
92hatchLX's Avatar
I changed my oil and got them same noise. I've heard Motorcraft XL7 is the cure for it on the 2011-2012
92hatchLX is offline
Old 10-19-2011, 01:58 PM
FordService
Official Ford Rep
92hatchLX,
Motorcraft fluids are specially formulated for the best performance, so if you are having noise concerns, try switching to it.
~Natasha
Old 10-20-2011, 12:46 AM
doode
doode's Avatar
Did i miss something?
Differential friction modifier is a fix for engines now ?
doode is offline
Old 10-20-2011, 11:50 AM
Ricardo
Ricardo's Avatar
Thanks Natasha, will do.
Also keeping on original topic, I checked out TSB - 05-15-8 and it says that the VCT will tick when the engine is at operating temp and at idle through1200 RPM. This is exactly what I experience...around 1200 RPM it goes away.
Ricardo is offline
Old 10-20-2011, 02:18 PM
Derf00
Gentleman's Relish
Derf00's Avatar
I was just going to point that TSB out. I don't remember the details but I believe it has something to do with a cam followers or related valve/cam part (typically on the drivers side).
Anyways, it's considered normal and I haven't seen anything with regard to long term problems (wear).
Derf00 is offline
Old 10-20-2011, 03:24 PM
FordService
Official Ford Rep
My pleasure. Have a good day!
~Natasha
ShaneB26154
35
03-04-2021 04:05 AM
msavoia23
12
07-07-2018 12:08 PM
drfister
05-03-2018 10:38 PM
Spiral534
10-06-2015 04:31 PM
Philhampton1
08-21-2015 12:04 PM
Quick Reply: loud low rpm engine tick
