Alot more noise after a short-throw installed
I'm hoping someone out there in Stangland can offer something here. Since installing a Roush short-throw shifter, I can hear alot more cabin noise, mostly coming up from the shifter itself, in fact I can change the noise somewhat by moving my hand around on the ****. It's mostly what I've come to find out is called "gear rollover noise."
The mod only replaced the shifter body and the vertical arm, allowing me to retain the stock ****, so not much changed. It's a really great shifter other than the increased noise.
This one:
http://store.roushperformance.com/detail.aspx?ID=1177
I already asked my guys if they forgot to replace some insulation or something, but they said everything was put back. A few people I've spoken to mention that the new assembly is not cushioned as well, but can that really contribute that much? What's actually causing this??
I've heard about the benefits of Dynamat, and may try it out if there is nothing else. Though I'm not sure just how much sound will be dampened, or even how to place it inside the console so it will dampen the sound without hindering the shifting (which is already a little harder with the shorter throw).
Any advice would really help, as alot of you dudes know a helluva lot more about this stuff than I do. Thanks so much.
This one:
Aftermarket shifters use polyurethene and/or brass bushings. This will lead to an increase in noise, vibration, an harshness (NVH). However it eliminates the "sloppy" feel of the stock shifter.
The factory shifter will be much quieter, but due to the stock rubber bushings which insulate noise better, it will have more play. You'll get used to the increased noise of the aftermarket shifter over time. Cold weather tends to make the aftermarket shifter a little noisier as well.
I have the same shifter with the billet arm. Extra noise is the name of the game when you do these shifters with firmer bushings. I did reduce it somewhat with dynamat though. I used the speaker kit they sell at autozones and such. Lay it out and use a razor to cut an X into one of the sheets after its installed. The resulting triangle shapes get folded down into the tranny tunnel and pressed on the underside. This reduced noise a good bit. But if you wanna go another notch find something you can replace the stock sound deadening slab with. Maybe some audio install stuff.
Also, what is the sound deadening slab, are we talking about the entire area directly below the removable console?
Yeah, when everything is removed from the area, the Dynamat gets attached directly to the floor pan sheetmetal. Just lay it in without peeling the backing and trim how you want. Then peel the backing, press it on, and then cut an X in the center and fold the triangle tabs underneath. Then you reinstall the shifter dust boot, drop in the factory sound deading slab (block,slab,section, whatever you want to call it) The slab is just the factory sound deadening piece that has a hole in the center for the shifter arm. It just drops in and hangs out just below the console.
If the sound reduction is noticable, it sounds like it's a worthwhile project.
I'm so glad someone else has recognized the increase in noise with these things. I mean I did expect it, but when I asked about it a while ago I kinda got the impression that at least with the MGW it should be QUIETER than stock. Well let me tell you: even the MGW is louder than stock. I guess it's just the nature of the beast.
Be thankful you don't have the separator plate buzz; I think that's what I've got and the sound inside is now kinda nasty around those RPMs.
