Shaker 1000
Shaker 1000
Is the head unit (6disc indash) have a build in amp for the sub/spekers? See I would like to replace the 6disc head unit with a touch screen but would like to leave the speakers/amps completely stock. I know It is a waste to get the 6disc but this is what I would like to do.
RE: Shaker 1000
The head unit has internal amps for the door and deck speakers. The subs are powered by external amps. Two in the trunk behind the woofer box, and two behind the drivers side kick panel. There are wiring harness adaptors that will allow you to replace the head unit and use the stock speakers, wiring, and amps. It is pretty simple to do. After 4 warranty replacements of the skipper head unit, I replaced mine. Search in the forum for "fix for skipper 1000" for the thread on my replacement. I have part numbers listed for the wiring harness and for the dash spacer unit you will need.
RE: Shaker 1000
Hawgman,
When you replaced the head unit, do you notice an improvement in sound? If so, what improvements did you notice. I was thinking of replacing my head unit but wasn't sure if there was any significant improvement in the quality of sound.
RE: Shaker 1000
ORIGINAL: hawgman
RE: Shaker 1000
ORIGINAL: 05BlueGT
Hawgman,
Hawgman,
RE: Shaker 1000
ORIGINAL: dajohu
I took pics of it all when I had it all apart to install my sequential tail lights.
RE: Shaker 1000
ORIGINAL: fiddy
Would you mind if I would see the pictures? I have not ordered a car yet so I would like to see how much room it takes up as well.
ORIGINAL: dajohu
[IMG]local://upfiles/13830/02D4A41A95F64F338CD8555F1C106903.jpg[/IMG]
[IMG]local://upfiles/13830/A8E70F0292AF498E9EBD756E455DBF4C.jpg[/IMG]
[IMG]local://upfiles/13830/0E75596A042A49ADB0569F3F6A354438.jpg[/IMG]
RE: Shaker 1000
[IMG]local://upfiles/13830/A74A39300344442286F30A53101D6B0A.jpg[/IMG]
[IMG]local://upfiles/13830/BBB9850A5B3C4A24A927FA5C78C0017F.jpg[/IMG]
[IMG]local://upfiles/13830/EA95288E2F60412ABF9ECA00AE812B74.jpg[/IMG]
