reconnecting battery...which one first?
Quick question for you guys. Had to disconnect my battery and now I'm going to reconnect it.
Do I attached the positive (+) cable FIRST, then the negative?
Or do I do the negative (-) cable first, then the positive?
Thanks guys. Couldn't find this info in the owner's manual.
Even the non-noobs screw up occasionally. The Tech Correspondence column in the June 2010 issue of Road & Track got it backwards. They corrected it in the August 2010 issue. BTW, the August issue compares the Mustang and Camaro. Mustang 1, Camaro 0.
When removing, always remove negative first. Same reason as putting back on the positive first: if the wrench hits the frame or any other metal part when you're on the positive terminal, if the negative terminal is still connected, you'll throw a load of sparks and can damage stuff. If the negative terminal is being worked on and you touch some part of the car with the wrench, it won't matter.
Remove negative first, then positive.
Put it back on doing positive first, then negative.
And do NOT get them crossed and put them on wrong!!!!
TfcCDR
09-14-2015 12:08 PM
'stangdude
08-12-2015 01:27 PM
