Sponsored by:
Sponsored by:
Coolant temp help
Old 08-23-2010, 08:15 PM
NJMustangGT
NJMustangGT's Avatar
Default Coolant temp help
I have a 06 gt with a build block and a stage 2 procharger with a d1 sc head unit and a upgraded 800+hp innercooler. my coolant temps right now are about 205. is that too hot or is that about normal. i want to know what a good temp should be for our cars under boost. Anyone who is blown how hot is your coolant temp getting up to? need feedback thank you. i am running about 17lb of boost.
NJMustangGT is offline
Old 08-24-2010, 02:53 PM
NJMustangGT
Old 08-24-2010, 03:28 PM
hammeron
hammeron's Avatar
check your fan turn on/off temperatures, make sure they are where
you want them.
hammeron is offline
Old 08-24-2010, 07:19 PM
vasman
vasman's Avatar
+1 on Fan speeds. Also, If you are concerned about the 205 (which is normal), spend the 20 bucks (or less) and put a 160 degree thermostat
http://www.brenspeed.com/hyp1011.html
My car in 100 degree houston weather with fans set at 170 low and 180 high (both min numbers on sct tunner)
operates in the 174-79 range City, top down no ac. City Top down Normal ac 185-87. City Top down max ac is abt 194. I do not see 200 anything any more even in traffic.
As you can see the parasitic loss in a hot environment will play with your temps
vasman is offline
Old 08-24-2010, 07:22 PM
vasman
vasman's Avatar
Now If you are taking about inter cooler temps, that does not exceed 135/140, with a usual range about 125. Mind you I am only on 10psi
vasman is offline
Granatelli Sales
01-20-2020 12:34 AM
wraith777
09-28-2015 10:49 AM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Coolant temp help
