My 2011 GT AKA "The Bloody Angel"
#116
Thanks!
Haha well keep watching!!!
Thanks man!
SO here is the update! I just got the car back from the dealer... with new pinion and gears.. Ford Racing 3.73 this time yeah baby! I then raced my buddy on the highway.. 45 roll and smoked him.. It was awesome. I really need a dyno tune for it though, because I can still tell that I am not running quite right..
I am throwing this code...
P0155
I looked it up and saw this...
P0135 - HO2S Sensor Heater During testing, the HO2S heaters •Blown fuse
Circuit Malfunction (HO2S-11) are checked for opens/shorts and
•Short to VPWR in harness or HO2S
excessive current draw. The code
will set when current draw exceeds
•Water in harness connector
a maximum calibrated limit or falls
below a minimum calibrated limit •Open VPWR or GND circuit
and/or an open or short is detected.
•Low battery voltage
•Poor electrical connections from PCM to
HO2S sensor
•HO2S heater
•PCM
P0141 - HO2S Sensor Heater Same as DTC P0135, but See Possible Causes for DTC P0135
Circuit Malfunction (HO2S-12) downstream Bank 1.
P0155 - HO2S Sensor Heater Same as DTC P0135, but Bank 2. See Possible Causes for DTC P0135
I also have some exhaust pypes clanking around so I need to go secure those better somehow... Well thats it... Oh and the body kit is here!
P0155
HO2S sensor
•HO2S heater
•PCM
#118
#119
Thanks.. 3dcarbon Body kit is going on it middle of this month..
Thanks I am working on it!
