Windows won't go up or down from the switches.
Ive got a 2008 mustang gt and recently my windows wont go down when i try to roll em down. they go up n down when i open and close the door but they just wont roll down from inside the car. i checked the fuses anyway even its pointless if they still go up and down but they're fine i have no clue whatsoever where the problem could be
So the short drop works on both the pass and drivers side?
And the switches on BOTH door panels dont work both up or down?
Need more info to diagnose a 1000 mile away unseen problem.
If the short drop works, the fuses are good.
The motors themselves contain the window logic for the assosciated side only.
The two systems are totally independent except for the fuses.
A problem with both windows but only the drivers side switch
not working is plausible, but both the drivers side and the pass
side switches not working at the same time is weird.
It can be diagnosed with the correct and total assessment of the
problem.
Assess and report back...
problem.
the short drop works on both but both switches dont work up or down that's why i have NO idea what's going on both decided to just stop working a few days ago. sorry about the small amount of information im just freakin out about why this happened
Just kidding.
I don't understand how both sides could not be working if what that guy up there said was true.
If anyone still has this problem, I did too with my 2008 stang! The short drop worked fine but both the switches didn't work to roll down the windows! Then I put in a new Accessory delay relay in the smart junction box, (SJB) locating behind the right kick panel and just like they should, the windows went down!
I hope this helps!
I hope this helps!
