Aint got no traction, aint got no sole
so right now, Layla's got about 35k on her, which means I gotta get her tires for her birthday
right now she's on BFG 235/50ZR18s, but I'm thinking I'll get 255s
these'd be DD tires, so dont recommend me any slicks or whathaveyou
also, I'm a poor twenty-something, so I'd like something thats not HOLY**** expensive
so recommend away!
so recommend away!
so recommend away!
so recommend away!
EDIT:
Correction, they have lowered the price to 128 each.
http://www.tirerack.com/tires/tires....RCAR&tab=Sizes
oh yeah, also: whats the actual difference between Summer and All Season tires? from what I understand, they are pretty much the same in wet conditions, and i dont really get ice and stuff down here
also, thanks JD
also, thanks JD
If you plan on owning your car for a while longer, I would suggest buying the absolute best tire you can afford. I've owned 53 cars and I've finally learned my lesson. Tires are not the area to skimp. Cheap tires will likely be loud and rough riding. I would consider anything from either Nitto or Michelin. Cheap tires will make you enjoy your car less on every level and what good is that?
As for what the other guy was saying about cheap tires, these are normaly like a $350 a piece tire, I dont know why tirerack sells them so cheap. There the same tires that come stock on a GT500
Summer tires loose a lot more of there performance characteristics as compared to all season, as the temperature declines. I live in Connecticut, so in mid spring to mid fall, my Supercars do very very good. Especialy when you consider price. However durring the colder months, like anything below average temp of 50, they dont do so well. Not to say you cant, i have driven them in the dead of winter also. But with over 500 HP and 4.10 gears, its alot to ask a summer tire to get you good traction at 40 degrees.
Now is the time to grab a bargain!
Eric
