Shaker 500, aftermarket HU, and steering wheel questions
Pull your radio out first and take a look. It only takes a few minutes to pull it out. honestly, you can have it out in 5 minutes. If it has two plugs, then it has a wired remote turn on. If it has three, it uses a turn on signal from the canbus, and you need the expensive one. On a side note, did you see where I linked the parts? Unless your set on crutchfield, you can save some cash.
I had the shaker 1000 in my 08, she had a shaker 500 in the 09. Aside from that the only difference was hers also had the mycolor option. But between the two cars it was a entirely different animal when it came to wiring.
If the car doesn't have NAV, then it won't have C BUS harness requirements.
Also, this link will help answer questions about the 5 volt mod.
AVIC install help
Ignore the title, this will still give you assistance for your install.
AVIC install help
False... man I keep seeing people post in here about our stereos with out knowing. I mean if you bothered to read page one, you would see where I described multiple times that my moms shaker 500 had the canbus interface and no remote turn on for the radio..... This isnt like I am guessing, or I have only seen it one way, I dont know how much more clearer I can be.
SOME SHAKER 500s AND 1000s DO USE THE CANBUS INTERFACE AS WELL, AND DO NOT HAVE A REMOTE TURN ON LEAD TO THE RADIO. NOT ALL SYSTEMS INSTALLED IN OUR CAR ARE EQUAL. THE EASIEST WAY TO TELL WHAT INSTALLATION ADAPTER IS NEEDED FOR INSTALL, IS TO PULL THE RADIO AND CHECK TO SEE IF IT IS 2 CONNECTORS OR 3 GOING TO THE RADIO. IF THERE IS 3 CONNECTORS, YOUR RADIO IS INTERFACED TO THE CANBUS. ALL NAV UNITS ARE, BUT ALSO SIRUS EQUIPPED MAY ALSO BE.
This concludes my rant, I just want people to stop spreading misinformation.
<----- Pro car audio installer for 12 years.
besides, do you know how much money I can save someone by avoiding the extra expense of the added module in this car (and have in various other cars) by tapping switched power elsewhere. It's not like he has NAV on that radio needing a speed sensor wire or other vital functions (I can tap that elsewhere too). Geez!
Those cars must be rare, because I haven't came across a Shaker 500 NON-NAV yet that has C-bus, and if I did....do you think I'm going to cry because I don't have a turn on wire. No, I can find that in multiple other locations in the dash area.
Tell me this, how much are you going to charge for a customer that would walk in, want everything enabled, including the cheaper harness. To tap everything they want tapped, and the fact that any shop you can walk into is gonna be charging, probably $19 for the regular harness (give or take $5) You gonna tell me a professional shop is going to charge less then 80 in labor to run there own remote turn on, tap the computer, tap the transmission or the reverse light itself, tap the brake, tap the headlight switch and run the sat cable? No shop up here will do it that cheap and have it all enabled.
I get what your saying, anyone with a lot of experience, electrical and mechanical know how, CAN get it installed without a problem, no matter what is in the dash. The point is the information were putting up here is for some one less experienced. Also the information is now in a public database where were talking to a audience where 90% of the people wouldn't be able to do it. So unless your trying to drive up your personal sales for botched installs that someones friend said they can do for them (yeah, I know installer speak too) we need to watch the advice we give and check for accuracy.
AVIC install help
AVIC install help
Thanks for the link. I've heard the popping sound isn't bad, but that doesn't look too hard to install. I've never installed an aftermarket radio, so hopefully I can find which wires that uses.
Oh and one reason I went with the fancy harness is because my radio is nav ready, I just have to get the nav unit to put in there. When I get back to the states I'm planning on doing that, so the fancy harness just makes everything easy.
My "save money" comment was based on the need of an ignition power only, and the non-needed module assuming the car had C-Bus. If I needed more, I would tell the customer he would come out cheaper to buy the module. Five minutes to tap an extra wire for switched power isn't a big deal when I can transfer minimal (versus the module) money to labor instead of selling a module they really don't need. But again, so far....OEM NAV units only thus far.
you might want to be careful with the highlighted area as its not true for all cars. For example, my car the $10 harness was fine. My moms 09 with mycolor option however, was not the case, as I painfully found out. The difference is in her car there was a third plug that mine did not have. That was the communication circuit, not sure if our cars are canbus or whatever. Anyway, long story short, there is no switched input on hers. The module creates a switched input for aftermarket radios
I f"in lose it sometimes when guys spend hundreds of dollars on a unit, and then try and skimp out on a cheap harness to wire it up!
You are tripping over dollars to get to pennies doing this with the time and trouble it saves you with the install.
PAC harness wired to the aftermarket harness, ready to install. The little black box is the control module that makes it all function properly...without it, problems will likely occur. Good luck with the install.
JD I respect your knowledge but you are making this harder than it is. You CAN make your own harness, with resistor for the amp, without spending $100+ on the PAC harness. If you are a person that likes convenience, by all means. If you don't have the know-how to build the harness correctly, by all means. Otherwise, save yourself some money.
