motor mounts or torque brace?
O.k. guys and gals, which would you choose? I'm tired of missing 3rd gear at WOT because of the torque binding up the driveline. Would you do prothane motor mounts or the CHE Torque brace limiter? Or both? I have a short throw shifter (hurst billet) which i am totally fine with.I havent heard of anyone needing both the motor mounts and brace ,but I'm sure some do.Thanks!
I have prothane mm's. You feel the motor more while driving. I can remember taking it out for a drive the first time thinking it was kinda harsh but I don't notice it any more. Install does require jacking the motor but it's easier than it sounds. If you ever do headers do prothanes at the same time since the motor mounts have to come out for headers anyway.
I never liked my hurst for drag racing. All the shifts seemed to bind some.
Just on pure theory and design, I'd go with the urethane motor mounts first. The motor mounts, and the associated connecting points, are designed to deal with (and survive) torque-over of the drive train. This is their sole intended purpose. The bell housing, and rear of the engine block are not designed specifically to withstand those stresses.
Given the option of replacing a part with an upgraded version of itself, or adding a completely different part to try to cope with a different part's issue... I say replace the actual offending part. It's kind of like if you have a debilitating illness. Do you want the doctor to just treat the symptoms, or do you want him to get you a cure.
jwog666
12-27-2021 08:09 PM
logan409
09-26-2015 07:43 PM
