Sponsored by:
Sponsored by:
Old 10-20-2015, 10:53 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
Squeaking Noise, Please Help!
Old 05-11-2014, 02:38 AM
drewsky
drewsky's Avatar
I had two noises that took me forever to find.. May not be yours but look for peace of mind.. 1. Exhaust hagars in the middle if car right behind the tranny. Take a screwdriver and bend it a little so it's not rubbing on the rubber bushing. It looks like it's impossible to make a noise but it was a loud annoying squeak.. 2. The sway bar end links, had to talk to Sam Strano the suspension expert to find this one. A 1/4 turn will make a difference!! Small maybe 5mm bolts.. Red locktite and a good tighten town made a world of difference! This may not be your problem at all but it's worth a shot ??!
drewsky is offline
Old 05-12-2014, 10:34 AM
mustangspotential
mustangspotential's Avatar
Time for me to chime in here since I had the same problem. It drove me nuts and I literally almost sold the car because of it. Every time I hit any kind of road imperfection, there would be loud squeaking and it was very audible standing outside the car as well as the cabin.
I changed to aftermarket LCA's, changed nothing (although this is a source of noise for many people and could be it.) Then I changed exhausts to a Pypes O/R H, and it got worse. So this lead me to believe it was the exhaust and it was. $2 later and the problem was solved. Check your exhaust hangers right by your mufflers (especially if you have an aftermarket exhaust.) Also check them by the transmission. The metal hanger rubs with the bracket and causes squeaking. Get some rubber, cut it, place it over the hanger near where it meets the bracket and zip-tie it. Problem solved.
Let us know how it goes.
mustangspotential is offline
bjdutch2005
03-24-2017 03:38 AM
KingRando
10-02-2015 08:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
ccdguy
09-19-2015 05:20 PM
Quick Reply: Squeaking Noise, Please Help!
